survey brand of absorber used on ae101
feipepe
293
13
balakong
hi to everyone sifoo,
right now i tries looking around suspension for ae101, because my rear absorber now already sound "kong, kong" while in inflate road. thus, this is the time need to exchange my absorber. so that i open this title as mentioned above, hopefully can get survey that recently 4AGE club member using.
tips: i wanna to absorber set more stiffness than local made ae111. and not harden than like abjustable. have everyone sifoo can advice?
chuckie
508
23
Titan Adjustable at Pandan Indah. Call Mr Richard at 013-3506561 @ 03-42979878
I've been using their suspension for my three cars b4. Corolla SE, Corolla SEG and Corolla Altis.
Current using stock bcoz car still under warranty. No regrets bro. Use their absorber and ur spring > comfort and superb handling for high speed at cornering.
nappx
2,532
185
5,163
kLaNG-kEy_tEE
lot choice at market..from used to brand new..
stock absorber with stock spring
-kayaba made in malaysia, tokiko
sport absorber with sport spring
-trd sport spring with trd abosrber
- gab sport spring with absorber
- etc.
adjustable
- tein..hi low only/ high low-soft hard
- trd
- jic
- buddy club
- tom's
- gab
- etc..
bera
822
229
1,543
currently riding on cusco HL/SH...i have to admit that the transition phase between stock to adjustable is a "vomit inducing" experience...harsher ride couple with annoying noise is the down side of it...once get used to it...there is no turning back...the fact that my crappy car can turn at speed in access of 120/kmh without breaking a sweat is really amazing feat on its own...
bottom line is...(regardless of brand)
1. comfort = stick with oem/uprated dampers and springs
2. dress up (lowered ride height + improve handling) = oem/uprated dampers + lowered/sport springs
3. wolf in sheep clothing = adjustable coilovers is the way to go...
mamatAE111
301
52
Uprated absorbers no experience. But heard good things about Titan, you should call them.
I only use have experience using stock and then straight to adjustables.
me2kimi
717
276
1,563
Puchong
My SEG use Potenza Gymkhana soft/hard adjustable with APM Performax at front and HIT Hi/Lo adjustable at rear.
Good enough for me to tackle a corner.
For my opinion, if you want to use abs stiffer than stock, I would like to recommend full set APM Performax abs and spring.
Originally my front absorber came with Espelir spring, but I still choose performax spring cos of stiffness.
2slow
431
082
i'm running with trd low spring front n rear.front trd abs rear kyb japan abs
so far happy with it
heard tein HA bang for bucks :driver:
feipepe
293
13
balakong
chuckie bro,
as ur mentioned, the Titan adjustable can set hi/low, soft/hard as well?..how much for ur whole set absober for seg ?:hmmmm:
---------- Post added at 08:32 PM ---------- 6 hour anti-bump limit - Previous post was at 08:29 PM ----------
mekimi bro,
want to ask regard ur Potenza Gymkhana soft/hard absorber. where did u get it..? bcoz i never heard this brand before? is that local OEM? or halfcut japan?
---------- Post added at 08:32 PM ---------- 6 hour anti-bump limit - Previous post was at 08:32 PM ----------
mekimi bro,
kayy
453
Titan
2 years hassle free local warranty..limitless setup in between..good after sale service
meg_omen
421
96
3,028
Home - Klang; O
You buy TITAN, you actually buying a solution instead of absorbers.
Price roughly RM2,900.
H/L able to adjust by yourself, but S/H need to go back to TITAN.
Using it on my AE110, and wife's MyVi.
me2kimi
717
276
1,563
Puchong
The Marketplace Top Posts
Lets take for example a Wira 1.5Gli it comes stock with disc in the front plus 2pot calipers (i think) and drum brakes at the rear.
So if was wondering if wanna get better performance ..
1) Transplant ABS from a compatible Lancer set.
2) Upgrade the rear to disc also, upgrade the front to bigger ventilated disc, and upgrade calipers from 2pot to 4pot (for example).
I think (1) would be the obvious solution if doing an engine transplant as everything would be compatibe but if it wasn't a...
