Soulfly: I use Arrow Metallic Paint. RM8.50 at hardware shop. I spray over 5 times of coating. I wonder will it withstand the high temp. My fingers crossed!
p/s : advice for those who wanna paint their valve cover. Please get a new gasket seal for the valve cover and the spark plug rings. Also you'll need some silicon to glue the corners of the gasket. This is to prevent oil leaking at high revs.
Originally posted by simplythebest@Mar 21 2004, 11:26 PM Can I spray my current 1.3 one? just to make it nicer .. there are many stubborn stains on it :( ..
Oit, i've sold my car moons ago edi. Now driving a stock standard Sentra lar! :) How fast & garang would a 1.8 GXE be? Moreover, it's an automatic. <_<
can i choose not to remove the cover... ??? have to get new seal and stuff very mafhan la.... and i found out that my screws on my cover are not tight.... can even twist with finger... izit alrite?? they purposely make it likt that or wat??
great job with the paint jobs. I was just wondering if i would want the wordings on the cover in a different color..wat can i do?mask the cover n leave the wordings??itll be such a hassle dont u think?.Any better solutions??? thankz
how to post step by step? different engine got different srews and bolts wo.. what engine u are having? Usually most rocker cover can be removed by the following steps.
1. Remove spark-plug cables from the cam cover.
2. Remove timing belt cover.
3. Unscrew all bolts and nuts u can see on the rocker/cam cover. With slight force.. u should be able to lift the cover once all bolts are unscrewed.
4. if u successfully removed yo rocker/cam cover u should be able to see the rubber gasket.. if the gasket seems soft and has no crack.. means in good condition. If got crack.. it must be replaced.
5. Clean the cam cover with petrol.. before spraying.
6. Remove old silicone layer.
7. Install back once cam cover is dry just like how u took it off. And.. dun forget to reapply silicone glue before reinstalling.
Parts needed
1. 10mm spanar
2. Silicone glue
3. Petrol - RM1 enuf already
4. Painting Brush Hard type brush.. ( to clean the cam cover 1 lah )
5. Color Spray of your choice - spray more coats lor.. looks better. -refer to spraying techniques.
6. New gasket - if ur current one rosak or not in good condition la..
Hey guys, just got an 84-85 Prelude. Its got a sunroof but can't seem to get it open. I've been doing a lot of work on the car on my own but I don't feel confident enough to remove the headlining and tackle the roof.
Does anyone here know anyone who repairs sunroofs? I know its quite a big job as the motor might be dead or something inside the headlining is broken but I really want this thing to work. :)
Thanks!
