Piston to valve clash..valve broken and embedded into the headblowing out engine? describe this : melted piston? bent conrod? blown block? cylinder head knocked off from block? bent valves? which one?
---------- Post added at 08:02 PM ---------- 6 hour anti-bump limit - Previous post was at 08:01 PM ----------
Yes that is true, bro. Next time i will find the right tuner who is using dial gauge to dial in the cam..even it didnt alter the lift, regrind or even new cam might have difference lobe height from original cam..should adjust clearance..
and ive heard regarding running-in camshaft...certain period in high rpm and certain on low rpm..
and also proper lubrication during installation...
might also check for timing...
those are the quality/assembly problem...cant do much...
need to ignore..
yes, the intake box cause rubbing under the hood insulation...nothing to worry...plastic to rubber...
i dont have the same problem...
but when it happen to me, surely the battery have low voltage...
