yo guys...
i need help again with my camber lah..heiyooo, i tell you, the `96 civic ej6 not having a camber nut is a real nuisance...right now my camber is tilting outwards..this means negative camber rite...my tyre makan on the outside part...my mech advised to push back the whole arm using the pump..i`ve done this earlier but i was warned that if it is done excessively, the bearing might get stuck...my question is is this true and is it safe to use this "pump" method?
really need some advise guys...thank you.
G.
G.
