my Optima suspension probelm~Help
David_KIA-Racing
3,569
Pahang~KL
www.mynazakia.com
Now my Kia Optima using 18''wheel...and the rim too big,will hit my car maguard.
then i go mod the maguard to inside...but dun know why still hit dun know where.
and i ask some shop no any product hard adsorber for my car...
so how i can mod my suspension hard a bit...dun gv me rim hit my car again...:cry_smile:
If my car now 1driver n ppassenger then ok,but if rear more 1 passenger then wil it it again.
WHY??my car 4door n luxuly,but jz can sit 2passenger.Oh my god~
Pls Help...
acbc
4,615
KD
Why not increase the ride height?
You have to take account of the following factors:
1. 4 passengers
2. 1 full tank
3. 1 full boot - with ICE or daily errants
k3nny
383
Bro, if i am not mistaken, the current Kia Optima is based on the same chassis and design as the just recently updated Hyundai Sonata EF model..
I have a Hyundai Sonata EF and its running on 18's as well.. I put in HWL MT1 fully adjustable coil-overs for a slight drop and i have not scraped the fender since.
Im now planning to sell the coilovers after about 6 months of use as the Sonata itself is also for sale so its back on its original springs and it scrapes sometimes when under a full load and you hit a bump while turning.
So my coilovers are for sale and im quite sure that they will be a straight fit for the current Kia Optima. :)
PM me for more info like pics etc if you're interested.
k3nny
David_KIA-Racing
3,569
Pahang~KL
www.mynazakia.com
Ya...sonata n optima is same.
Ur diving a sonata now??
U mean is u use HWL spring now??
will it no low down ur car body??
Izzit full set front n rear spring??
will jumping or not??
k3nny
383
Yes i am own a Hyundai Sonata now..
I dont only have HWL Springs. Im using the HWL MT1 Coilover set which is all 4 shocks with the height adjustability and 4 springs at the softest spring rate.
It does lower my car abit but i didnt opt for it to be too low as i didnt want to sacrifice comfort.
The height can be adjusted anytime.
Full set front and rear coilover set(shocks and springs).
So far no jumping as i mentioned that i didnt drop the height too much and that the springs are the softest spring rate they have as i need the car to be comfortable. :)
chek_corolla
361
49
3,028
it might not just hit the inner fender, it might hit on the spring support, aka the mangkuk. check that out, if comfirm that the tyres hit on the spring support, u might just wanna consider change ur suspension to coilover type/adjustable suspension so u can have smaller spring support n more constant ride height. and ur last resot is---------> camber......
David_KIA-Racing
3,569
Pahang~KL
www.mynazakia.com
wah...sacrifice ar!!Hehe...so how much u wanna sale??U buy new is how much??
where ur location??I'm very very interest~
k3nny
383
David,
Thanks very much and it was nice to meet you as well. Sorry about not including the height adjustment arms clips/arms in the box as they were in the glove compartment of my car.
I am still waiting on HWL to give me a response on the price and availability of that single missing rubber cap from the rear left side.
Will let you know as soon as i hear from them.
Thanks once again
David_KIA-Racing
3,569
Pahang~KL
www.mynazakia.com
Ok la...so i wan asking u the height adjustment ars is got 2??
Erm...and the rubber cap when HWL answer u then pls let me know...
the suspension need service or wat anymore??
My original battery +ve terminal had corroded and teared off, hence, went to some garage in puchong to buy a new after market terminal (looked damn big).
After that I've DIY replaced the terminal. Yesterday on the way back from work, while driving at 70km/h, enverthing in the car (signal light, instrument cluster, radio, etc) all went hair wired and the engine suddenly cut out. Moreover, fire sparks are flying all around on the winscreen....Damn scary !!
Luckily I was at the inner...
