My neo 1.6AT FC Problem
fishyogurt
From Facebook
23
www.facebook.com
my 2 cents.. if you are willing to sacrifice abit of comfort, then go for 205/45/16..
then get those lightweight rims..for 16" make sure each rims are no more then 5.9kg per rim.. that should offset abit the disadvantages of using 16" over 15"..
by sacrificing abit of comfort for 205/45/16....then what is better? 15?
reefdee
97
5
1,508
Putrajaya
15" with 55 profile tires.. good balance between performance and comfort..
16 with 45 more to performance..
16 with 50 or 55.. more to comfort..
reefdee
97
5
1,508
Putrajaya
up to you laa what you want..
but a neo with 55/16 i have tried before..
poor acceleration and this is after i have done quite some mods to my neo - custom exhaust.. acp, lcp, iridiums+plug cables, pdt and some other minor stuffs..
at 50/16.. ok laa.. still poor but ok laa.. liveable laa.. :driver:
The Marketplace Top Posts
The reason probably you are here is may be you are wondering "What this Water less Car Wash is?"
Water less Car Wash though a new commercial concept, but it has been here since almost 20 years.
KKE Dry Wash liquid needs to sprayed on the car in segments and then wiped off using a clean Microfiber Towel.
Use strokes in one direction only.
For each stroke, a clean area of the microfiber should touch your car surface. Allow the liquid on car to dry if the dirt has been removed...
