sorry bro. dont know what is the measurement. try ask bro napxx maybe he knowshi bro, wud u mind to tell me, how long is ur trumpet (length)?
u can't play with vtecs without high cams. fyi, 272 cams still give stable idling. u won't go FAR without cams. that's the most obvious HP gains compared to other mods (except BOT). u need another piggyback or standalone to further fine tune ur cams settings. just my 2 centsactually is not recomended to use high cam, now a lot modification is not using high cam la, bcs the timing will not stable also, but if got ppl use it then timing still stable pls let me know. and then better to keep the vvt......actually if u need performance a lot thing u can do....
It will not fit if the tapak is different. BT trumpet cannot fit SVT tb and vice-versa. That's the only issue of 'cannot fit' that i can think of.hmm..but,how we know that the trumpet height coz normally seller didnt give the details on the dimension?if we buy then it wont fit, then it a waste&need to send to the machine shop..IMEC trumpet that I've saw, normally the pricetag is bout 400++ wor,lot xpensive than the aluminium or alloy trumpet:hmmmm2:
ha ha hai'm happy with my open trumpet & 272.
lalalalalallalalala.....
Basically u just need 4 pieces of stainless steel cups, can get them from any indian shops near masjid jamek or brickfields or any other shops selling indian cookware n stuff like that. Various sizes available from 2" all the way to 4". Then for the flange, u can try to source them from exhaust pipe shops or CNC them if you have a fren working with CNC machine. To get the flange dimension, you can either go to chopshops/workshops to measure it (look for BT ITB) but note that BT and SVT ITB has different sizes. Don't use the rubber trumpet that comes stock with the ITB because the diameter is smaller than the actual ITB's mouth.pcmoddingmy: interesting with your DIY. can u show us the step?
