Install trumpet inside plenum. Any difference???
alan_ee90
65
1,508
cheras
actually is not recomended to use high cam, now a lot modification is not using high cam la, bcs the timing will not stable also, but if got ppl use it then timing still stable pls let me know. and then better to keep the vvt......actually if u need performance a lot thing u can do....
20V Trumpeteer
252
130
Kedah
Hai to all,
I'm thinking to install trumpet on my engine (AE111 BT) but dont know which type should I choose coz I'm planning to put the trumpet into my plenum...coz I've scouting and there are 2 types..which 1 can be fitted nicely into stock plenum w/o any modification...thnx
nappx
2,532
185
5,163
kLaNG-kEy_tEE
if want to use trumpet inside plenum..onle short type & medium length can be used also..
it depend on length..
pcmoddingmy
1,147
101
www.pcmoddingmy.com
I think for BT 2" long trumpet should be just nice as anything longer will cause air intake starvation. I believe using IMEC 1" trumpet should also improve responsiveness as well.
Also note that the trumpet mouth type and length also plays major role in improving the air intake velocity.
Basically I just DIY the trumpets by modifying stainless steels cups which were welded into the flange... hehe
j_l200s
338
74
3,028
u can't play with vtecs without high cams. fyi, 272 cams still give stable idling. u won't go FAR without cams. that's the most obvious HP gains compared to other mods (except BOT). u need another piggyback or standalone to further fine tune ur cams settings. just my 2 cents:smokin:
20V Trumpeteer
252
130
Kedah
hmm..but,how we know that the trumpet height coz normally seller didnt give the details on the dimension?if we buy then it wont fit, then it a waste&need to send to the machine shop..IMEC trumpet that I've saw, normally the pricetag is bout 400++ wor,lot xpensive than the aluminium or alloy trumpet:hmmmm2:
j_l200s
338
74
3,028
It will not fit if the tapak is different. BT trumpet cannot fit SVT tb and vice-versa. That's the only issue of 'cannot fit' that i can think of.
regarding the length, u can ask the seller to measure for u. shouldn't be a hassle if the seller wanna do business.
pcmoddingmy
1,147
101
www.pcmoddingmy.com
pcmoddingmy: interesting with your DIY. can u show us the step?
Basically u just need 4 pieces of stainless steel cups, can get them from any indian shops near masjid jamek or brickfields or any other shops selling indian cookware n stuff like that. Various sizes available from 2" all the way to 4". Then for the flange, u can try to source them from exhaust pipe shops or CNC them if you have a fren working with CNC machine. To get the flange dimension, you can either go to chopshops/workshops to measure it (look for BT ITB) but note that BT and SVT ITB has different sizes. Don't use the rubber trumpet that comes stock with the ITB because the diameter is smaller than the actual ITB's mouth.
Then once you have the SS cups and flange, just need to weld them together and cut the bottom part of the cup. You can also use super strong glue (JB weld) to glue the cups to the flange but the result might not be nice for your eyes, unless you don't plan to showoff ur trumpet to your buddies I guess it doesn't matter how it looks if its inside the plenum...as long it does its job right.
Happy DIYing!
Mouse
217
Kelantan
Thanks a lot! will do it tomorrow...
the flange will make it at friend shop..
1JZtezza
371
42
firstly the sound from the 'open' trumpets is 'sweet'.
its function is to improve the 'flow' characteristics into the engine.
The actual gain is marginal except @ wide open throttle-without air filter restriction.
If installed inside plenum should use shorter trumpets lest the clearance from plenum body actually restricts air flow.As pcmoddingmy indicated you got to match diameter of trumpet to ITB.
It does not affect FC-usually its driver 'foot happy' becoz of the sound..hehe
Coupled with high compression pistons and high cams is when it actually gives a significant advantage.
20V Trumpeteer
252
130
Kedah
That's why I'm so eager to install the trumpet coz wanna feel myself how 'sssswwwwweeeettttt' the sound is....later,might be poisoned by sifu2 to be one who had a 'heavy-footed disease'...hehehe....but,I've read from the previous thread that open trumpet is not advisable coz the dust and harsh particles could enter into the engine same goes to the owner who use a subaru-like bonnet cos when in a rainy day, water could enter the engine via the trumpet.....hmmm,need to think very very wisely when imaging all these thing could happen:hmmmm:...sory aaa if I'm so talkative
My GTi's coin box door can't be closed due to some problems with its' latch. Somehow, the old latch wasn't latching to it.
So finally I had some time on my hands and decided to become a MacGuyver for today and dip into my dad's tool box. I found some magnets, screws, metal washers...and viola.. the idea of a magnetic latch like on those cupboard doors came to mind.
Anyway.. below are some photos of my DIY for those who are interested. If they don't appear here, then you may go to my...
