Good day...
Why ?
1) 20V engine normally hotter then normal engine...cuz of more moving parts...20 valve in one small engine...plus it's a cast iron block...not aluminum...and few other stuffs...all i know is, 20V is hotter then normal engine...
due to that ...using open stail VS (Velocity stack) will prone to suck hot air from the engine rather then fresh air...especially during traffic jem...plus you have to understand, VS are used for performance or track and so...high revving purposes, soo there's not much power on lower-end power...
it's different from using normal open pod filter where the intake hose when a bit further down, passing the radiator hot fan air stream and sit behind the battery pack...plus there's a stock CAI near the side panel...
you can use VS...but due to humidity weather here, not very adviceable...perhaps it's a good idea for you to start using CAI, costume plenum like most big turbo cars used or do a splitter or a heat shield on it...
simple fact ...colder air, more oxygen...more oxygen better combustion, and better A/F ratio...as simple as that...
easiest example...the engine performance while driving in the afternoon and in the midnite...which on is better... ?
2) if you using normal cheap engine oil...engine will have more frictions, heavy engine oil due to high viscosity...on high temp the engine oil won't have the protection for the engine part, more frictions happened, thus resulting hotter engine temperature and water temp...
solutions ? try to use a better engine oil...do a search on it...mobil 1, chemlube, royal purple, torco, motul turbolight and so on...do a search on it...
3) if you using toyota long life coolant...try to change it, let say after 3-4 times service intervals...
4) other stuffs you need to take a look too...thermostat, radiator fan, radiator water reserved (not too full) and so on...
that's what i can think of...feel free to add and feel free to correct me if i'm wrong...
happy forum-ing...:wavey:
