Did anyone tried the Pipe Sizing Calculator?
I found most parameters from Bill Sherwood's website and entered and substitute some numbers that I guessed.
Shortest is pipe is some 23cm, longest is 47cm.
6 results in all, due to various conditions / requirements. mostly around 30cm minus minus
Our 4 throttle is already 24.6cm. Long, hence adding a velocity stack of 10cm will be mostly enough. For that rev lah.
---------- Post added at 05:19 PM ---------- 6 hour anti-bump limit - Previous post was at 05:06 PM ----------
I redo the Pipe Sizing Calculator website using 3k rpm and one of the 6 conditions, i.e. shortest length is still 24cm, good lah.
But one of the 6 conditions, i.e. longest is 117cm, with 4 others around 60cm +/-20cm.
Fuuuu Woorrrr. Surprised!!!!! yet not surprised!!!!!
So what rpm we normally use? 4k right!!!
