Help On Modifications on peugeot 206 1.6 16v
ridt
Jan 25, 2011
16
503
hi ZTH members , need some help regarding modifications on my peugeot 206 1.6 16v AUTOMATIC transmission
current mod is :
1)4-2-1 extractor (custom by JFA based on peugeot sport setting, removed cat)
2)k & n typhoon air intake (long ram type)
3)topcat muffler s flow, piping 1.6 mid and 1.6 end ( all done at everco n really satisfied with it)
4)denso iridium spark plugs
dyno chart shows 122 hp @ 5.5k rpm and 164.4 Nm / 110 ft.lb / 15.2 kgm @ 4000 rpm , power to weight ratio at 0.118.
my last modification should be adding a unichip Q to total up the mods.... target is going to be nearly 130 hp with unichip.
1) lighten crank pulley or flywheel
2) port polish throttle body
3) intake manifold
4) hi camshafts
if i do all of those above, im looking at 150hp. but my $$$ doesnt allow as im still students , and some of those things costs 3-4k right? and even more.
im still nw to this modding scene, just wondering what u sifu's advice? to do before my unichip? if it costs 2k plus i think il just end it with unichip .
also for the other mods above, i dont know where to find it. tuning a peugeot is quite tough in Malaysia...
wondering where to do all those n the pro's n cons. pls advice bro's . and also what else should i mod ? thanks a lot :driver:
xtremeleo
3,247
464
i suggest u do no.1, get a lighten flywheel instead of lightening it, and tune it up with a management. shud set u back sum 3k imo
ridt
16
503
lighten flywheel ? not pulley? im quite confused between those 2.... where cn i get it?
cn elaborate more bro?
xtremeleo
3,247
464
yeah, flywheel, not the pulley. u can either buy it of the shelf, or order it online sir. i dont suggest a lightened crank pulley
ridt
16
503
so in KL suwnay area, which shops normally sell this lighten flywheel? does it require any tuning bro?
i googled and it says for faster reving? my rev naik pon abit slow la.
expected gains? thanks man :vroam:
p/s
is it a universal performance part? hard to get mod parts for my car
xtremeleo
3,247
464
i dont think there are any shop in sunway dat plays dis engine, OR i dont know if there are any, lol. installing a lightened flywheel gives a lotta different, so tuning it up is wise imo. just pm me if u need help in finding a pug's parts sir
ridt
16
503
ok bro, thanks. just pm-ed you. but i still need advice on what else to mod and where to find :(
pupjoint
98
21
i suggest you take good care of your AL4 transmission also. i doubt you can find any lighter flywheel for this engine, the stock is already very very light and thin.
ridt
16
503
yup, also going to install al4 cooler. but future maybe convert manual.
oh so actually no need LCP? what else bro?
---------- Post added at 08:35 PM ---------- 6 hour anti-bump limit - Previous post was at 08:33 PM ----------
how about lighten crank pulley as u said no need flywheel lighten :)
ridt
16
503
haha -_- im also planning to do next is port polish at nasty , okay or not? but i heard taht port polish cn also make climbing hill difficult as the ehad gets hot quick? im still considering this...
xtremeleo
3,247
464
i wont suggest porting the head, but iam fond of polishing it, not till mirror finish though.. tuning it up shud give better results afterwards
ridt
16
503
why not porting? as far as i know since porting is the one gonna give the highest gains..but also as i said some say when climbing hill its going to be a problem.
im planning to do at nasty port flow as they have flow bench also. any opinions on this place?
and btw why not till mirror finish?
hello all,
i got the GAB SS series adjustables for my vios. so, i will be spending time tweaking it! however, some queries below:
1. my front spring rate is 6kg and my rear is 4kg. with my damping set to hard, the car is bumpy, but in corners, slight body roll is noted. should i up my spring rate to further reduce body roll, or is slight roll acceptable? I have thought of installing anti-roll bar to the rear, but was advised not to do so as it may distort the suspension from doing its...
