fd door diffcult to close
keisukosan
316
7
u r rite....seems when u come in re club threat?jk oni,i go where also see u where ler,reli so kepo wan hahaha :biggrin:
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
I'm here long ago. Just less posting....just sharing what I know and what I experience before also. Nothing to kepo here...
stick back to topic.
ipohboy
68
31
The special tool to adjust the striker that Dev mentioned earlier is the Torx key size T-40. lend it or buy it.
Also try to put tiny amount of "rubber type grease" on the rubber seal outside the door frame that come into contact with the inner part of the body seal when you close the door.
Also put some grease on the slider that hit the striker and body to door hinge.
But don't expect it will easily be close with a push of a finger like Merc door. It's normal to push with a little force to close fd3s door. But if you have to slam it like mad bull then you have to adjust it. Adjust the striker with the windows rolled down.
phat7
2,122
62
brian thats why have 1 spare set. on a more serious note, the later model interiors are much more hardy and the clips are slightly more "pliable" so they dont crack easily.
muikit88
100
Malaysia
erm..actually i not understand clearly...coz my poor english lvl...
mind show me a pic ?
ipohboy
68
31
Which part you don't understand? It's really easy to get it done.
Sorry can't take picture because my FD is 300+km away from me at the moment.
muikit88
100
Malaysia
erm...i duno which part i need the fix... adjust the hook there or the door there ?
TitanRev
Mar 3, 2005
8,180
3,678
muikit. Striker is this or called hook. You need to adjust this.
This is the latch at the door wan. You need to apply some grease on this
TitanRev
Mar 3, 2005
8,180
3,678
the latch need open the door anot ?
or juz put sum grease on it ?
muikit, just apply grease at the latch. You see the 'longkang' on the latch right? apply inside the 'longkang' there will do.
I take no responsibility from failures.... :)
disconnect battery b4 doing wiring works... unless u are very sure of what u are doin.
