balancer shaft removal
xtremeleo
3,247
464
5,183
the risks are stated on this thread sir, i havent done dis mod on any car, i dont think its needed. it sounds cheap maybe because ur engine is already down sir.
dont get me wrong, dis will free up sum horses, no doubt but its not needed on street machines imo. iam speaking generally here..
spuzzle
741
9
Kuantan / Perth
as i know the risk of getting oil pump failure are fr those who cut the shaft...do u mind to elaborate more pls
xtremeleo
3,247
464
5,183
maybe iam thinking conventionally, looking at the function of dat balancer shaft, it balances the dynamic circular movement of the crankshaft assembly, to avoid resonance and vibration dat wud also rob power. so, when u remove dis, imo u need to fully balance the whole internal assembly, which will add more to the cost, which is y i said not worth the trouble and cost, since u can spend dat amount of money on sumthing else dat can provide more power ie turbo, management. i dunno if the tuner posted in dis thread rebalance the engine dynamically but from my pov, u need to perform dat especially if u wanna make power in the higher end of the revv. at least dats my opinion, like i said ive never seen the need to perform dis. the best dat i can think of is to lighten the shaft and rebalance the whole assembly.
maybe i got the wrong idea on the true function of the balancer shaft?
spuzzle
741
9
Kuantan / Perth
totally agree with some of your points, good info....thx
jameswwt
1,127
78
1,648
I have sent my oem bs for machining today.
Here are some pro's and con's by using the bs eliminator kit which ive gather thru internet :
The good
• More HP to the wheels
• Zero chance the balance shaft belt will fail and kill the timing belt
• Zero chance the balance shaft bearings will fail and damage the rest of the motor
• More oil pressure to the rest of the motor
The bad
• More vibration is felt in side the car (no more is made, just more is felt)
• More oil pressure to the rest of the motor, which is usually too much. Extra work to get the oil pressure back in spec.
Everything seem advantage on the eliminator kit, but ive choose to remain oem.
spuzzle
741
9
Kuantan / Perth
The good
The bad
james, what engine u using?
vrlution
690
this balancer problem, alway happen to vr4 engine, im use vr4 engine around 10 year already not major problem but, 2010 got one problem when first start engine at da morning and high rpm cos cool engine and got weird sound like balancer shaft ....all my mate vr4 was remove balancer shaft and no sound like knocking....happen again....do dat at srimuda...shah alam....but my engine still not revome bcos busy......if want to remove my advise dont just takeout belt only.....rightway all balancer remove out....if not damage ur engine problem come one by one like killer series....haaaa......
jameswwt
1,127
78
1,648
Evo 5...Dam...Im still in a delima on whether should i maintain the oem balance shaft????
Ahhhhhhhhhhh.....................Scary......
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
www.ftzoneracing.com
I've seen 2 EVOS had the balancer belt snap and ruin the cylinder head. In one of the case the piston was cracked by the brutal impact with the valve.
After that the balancer shaft was removed and replaced with an aftermarket unit from USA. The car is in used for track days... so far no issues. The crankshaft was rebalance of course.
jameswwt
1,127
78
1,648
Hi Ftzone, now im really scare after view yr sharing....Dam,ive done my crank balancing and i wonder will it be to late for me to put in the Eliminator Kit now???
spuzzle
741
9
Kuantan / Perth
before, i had problem with my balancer belt too but lucky enough because it dint ruin up my timing belt...that is why my mech advise me to remove the shaft
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
Well... i would suggest you use an aftermarket harmonic damper to go with the eliminator kit. Brands like ATI or Fluidampr is a good choice for high powered 4G63.
jameswwt
1,127
78
1,648
But ive send my oem bs for polishing and bought new bearings.
So,i have to give it a try maintaining the oem setup...:driver:
Keeping my finger crossing...
Btw, do you have any pics for sharing?
xtremeleo
3,247
464
5,183
y do u need to worry if the balance shaft is still there as the oem intended? we have a 360hp evo3 and it never give any problem, at least not yet. the engine is very smooth in operation dat u wud not know its running just by looking at it, if sumthing dynamic is as balance as that, i dont see y it wud any problem. vibration and harmonics has always been the culprit in structures and machines, i dont think sumthing dat balances any system perfectly does anything bad rather then, in dis application, robs lil amount of power from the engine.
jameswwt
1,127
78
1,648
Wow...its so comforting for yr sharing...hehehe (joking)
Yup,i am concern and doubtful as whether to maintain the oem bs or not bcos some say the oem bs bearings might will give way and ruin the pump and the rods bearings.
Thereby,by eliminating the oem bs this possibility will be "0".
Anyway,im glad to see someone share abt the reliability of maintaining the oem bs...:proud:
BEX 6162
Wira Sedan 1.6 grey...
bodypart wira black front
behind with evo kit
rim advan RR 16
