balancer shaft removal
1000hp VR4
83
But mines was Jeckings when rpm hits just around 5k rpm.Just gains more 6hp on Dyno with no problems in everythings.Im planned to finds stock shafts & install it back. Normally VR4 oil pressure was very incredibles no need to removes the shafts.Japanese has calcurated all before they produces this engine thats we used on today.This powerful engine famous in world.
Dont angry everybody just share my expreriance on removing BALANCER SHAFT.
jinkl
4,624
376
3,183
just take out ur ori balance shaft and sent them to machine shop laa cost lest then purchasing new so called race balance shaft. Actually they also machine it from the OEM unit.
of cos lerrrrr i posted n first post its a machine job jer, bt one of our fren already chopped his balanceshaft muhahaha, u know him :P , he is looking for a machined one now, stock vr4 balanceshafts are nt easy to find unless someone broke his engine
spuzzle
741
9
Kuantan / Perth
owhh...one of my fren also chopped off that shaft and facing oil pressure problem now :hmmmm:
1000hp VR4
83
Really not easy to find the stock balancer shaft.i have trying for 5 months now dont know got to go now.Did your there got friends stocks it.Thanks...:biggrin:
Trinityblood
3,371
21
erm..good info and feedbacks.good to learn this for new bie like me..juz wonder how much is the aftermarket one...
goo_61t
660
12
i got few stock balance shaft sitting at home :) evo n vr4 the same lerr.. u want kerr??keke
chopped balance shaft no good but still better then just taking out the balance shaft belt without removing or chopping the balance shaft kekekekeekekeke
pijulrs
217
16
Err....i had removed my balancer shaft belting.Im using it for around 5 years.No side effect except engine got slight vibrate n the engine feel more response.
goo_61t
660
12
definitely more responsive engine lighter but engine vibrate a bit, the slight vibration can cause damage to the balance shaft bearing and eventually ur balance shaft will fail and stuck imagine if ur balance shaft stuck definitely ur oil pump can't turn,oil pump can't turn then the oil pump teeth all gone catastrophic failure. But only time will tell some cases takes effect realy quick but in ur case it's been 5 years lucky u.. but it's just my personal opinion wether to remove or not it's ur choice. But why does all the race engine builder go through all the hassle to remove and machine them during engine rebuilt. it also depends on how u abuse ur engine though. If u want to remove the balance shaft do it the right way,don't short cut here n there.
zarique
203
Penang
whats been said by GOO are true...
i already kena with not more than a year running...:driver:
jinkl
4,624
376
3,183
balance shaft belt removed alone still practices worldwide including kampung and dsmtuners hehehe
no issues reported yet :P all running well
goo_61t
660
12
no point arguing about it, dsmtuners have been arguing about this issue and it's been a long argument weather to keep or to remove the BS. Some say ok to just remove the belt,some say cannot. Back to the basic of the BS function.
spuzzle
741
9
Kuantan / Perth
guys, brought this thread back alive because i saw something different.
one of my fren mech totally remove both balancer shaft by alluminium weld the shaft hole on the oil pump piece...and he roatate the shaft bearing on the block to prevent oil fr flowing through it with a tag weld
after done, i personally tested that engine and it feel great...is there any side effects to oil pump?
Local Models
Blue price: height adjustable kit (hi-lo), spring rates of your choice, for ultimate tunablity, be it street sport or all out racing.
Red price: fixed spring seat, using your stock springs, for the ultimate in comfort. An Original Equipment compatible replacement.
(usually for Family...
