balancer shaft removal
nan83
238
35
3,028
Pasir Mas,Kel
Ok, so by this logic, if say the whole engine was completely balanced to the 3rd decimal point (just hypothetically speaking) would it still need this counter balance shaft? What vibration does it counter? Where is the vibration from?
the nature of inline 4 engine is not balance.... if you do complete balancing also cannot, still need balance shaft no minimize the prob...
you can read here to fully understand it...
Balance shaft - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Balanceshaft.jpg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/8/84/Balanceshaft.jpg/250px-Balanceshaft.jpg"@@AMEPARAM@@commons/thumb/8/84/Balanceshaft.jpg/250px-Balanceshaft.jpg
http://www.autozine.org/technical_school/engine/smooth2.htm
dicktracy
21
sabah
anyone mind to share on pros and cons on removing 4g63 balancer shaft?
those experienced may elaborate more. thx
:proud:
So in my mind the pros of removing them would be:
* Higher oil pressure because the pump has to support less bearing space
* Less rotating weight ( More HP)
* No chance of BS bearing Failure
* Easier timing belt changes, and less failures.
The Cons:
* Possibly accelerated motor mount wear (but I doubt it)
* It shakes your butt.
spuzzle
741
9
Kuantan / Perth
the sifu speaks, good info bro
:proud:
The Cons:
i would say not much changes on oil pressure and be ready to get rock n roll....hahaha
jameswwt
1,127
78
1,648
Hi Spuzzle,
any update on yr balance shaft removal?
Mind to share?
Thanks
jameswwt
1,127
78
1,648
Havent install yet, been busy for these few weeks...anyway after install still need to run in for 500km i guess
You will be going for the Eliminator kit or u used back yr Oem Balance Shafts and change the bearings?
spuzzle
741
9
Kuantan / Perth
hey bro how much would it cost to get it machined and how much the labour cost roughly to fix it back ar bro???
i send my block only to rebuild:
changed piston rings #ori
changed rod and crank bearings #kings bearing
changed all oil seals #ori
machine balancer shaft
remove 1 balancer shaft and weld the shaft hole
honing cylinder wall
all this for rm1400...now waiting to install the block to my car ( doing myself )
i machine the oem shaft and replace the bearing, i would say it is better
any questions are welcome since we all share info here, maybe some sifus can give better advise
jameswwt
1,127
78
1,648
Hi Spuzzle, what do you mean machinig the oem shaft? you mean polishing the bs journal and where do you get the oem bearing?
Well, what i can share is after gather some info's frm the net, ive decided to used back my oem bs and just change the front and back bearings....As 1 of my friend after done the eliminator kit,the car idling and vibration is quite bad....But i dont mean the eliminator kit is unreliable laa....
nan83
238
35
3,028
Pasir Mas,Kel
"DO NOT SEND THIS ONE" = spuzzle already remove & weld the hole at oilpump
"SEND THIS ONE" = he machine this one & install back to block (this shaft attach to oilpump gear)
after machine it look like below :
it right spuzzle??
jameswwt.... the eliminator kit you say is like this right??
it just chop the shaft that attach to the oil pump gear.....
kumar22mostwanted
1,562
152
HELL!!!
it right spuzzle??
how much would it cost roughly to machine the balance shaft ar bro like above???and the labour to open and put back in???
is there a lot of diff from machining the shaft or just minimal??
spuzzle
741
9
Kuantan / Perth
nan, u r right...exactly like your pic...how is si kuning now? running healthy or waiting medical and treadmill examination? hahaha
james, the best is send your complete engine internals to balance to prevent vibration but my mechanic did few engines without any major vibrations...very minimal to notice, same like using racing engine mounting...maybe depend on lucks also:proud:
kumar, u can do this when u plan to overhaul your engine...not worth to mod the bs only
nan83
238
35
3,028
Pasir Mas,Kel
si kuning?? infected with cholera bacteria huhuhu... misfire at above 4000rpm while cruising... still not know the root cause.. huhuhu... already buy evo coil with sham paka, still not install yet.. now at offshore, need to wait another 1week diagnose si kuning...kekekek :nurse:
after settle that prob, she need to pass treadmill exam.... pass mark 450hp... huhuhu..
my engine oso no balance shaft & not done full balance, no major vibration....
xtremeleo
3,247
464
5,183
i dont think its worth doing dis mod for street machines, considering the cost and risk. u can always free sum horses from sumwhere else imo
spuzzle
741
9
Kuantan / Perth
aduhh, si kuning sick again....maybe weather change so cough a bit only...hehehe
just to share, our machines for weekend use only and we did it during overhaul...the cost to machine the shaft is too cheap to mention if u compare with what u spent on the engine...risk? mind to share what risks involve? coz i dont see any for now and many have been using this setup for ages
hi,
does anybody can recommend a good sport springs match with kyb rs? my car is an iswara.please state the price also.thanks.
