He is busy, probably next week.....Where's Bro Izso, Have he made his mind for this thread??
Not really. The length of the routing is about the same length as the stock routing. I think the only thing that might be lengthened is the path within the cooler itself. The stock cooler is just one straight tube.In that case, if proven problem will be solved, than now it's the option that matters rite? By u'r POV bout the cooler, IMHO, the single tube should do coz at point of exit of the cooler the ATF have the cooler temp entering back the gb. y, coz the ATF route to exit is longer so the cooling proses is longer.
Exactly. I'm also trying to find out which one will have an effect on my car, constant oil pressure or a reduced oil pressure will affect the performance of the GB.TS question is not which is cooler but which one not so restrictive in atf flow.....
Flat but multi tube or round but single tube?
Not yet decided. Just FYI, those tube coolers have fins inside the tube themselves, so in terms of pressure loss, those fins will bound to affect the pressure to some extent but cooling wise it'll probably be as good as stacked coolers.Where's Bro Izso, Have he made his mind for this thread??
Inside the tube got fins? Then flow is not good?Not yet decided. Just FYI, those tube coolers have fins inside the tube themselves, so in terms of pressure loss, those fins will bound to affect the pressure to some extent but cooling wise it'll probably be as good as stacked coolers.
Dammit. This is just a cooler. Why so difficult.
Debatable. Have a look at this :Inside the tube got fins? Then flow is not good?
I would not call them fins but more like partition. Accordingly to them more contact surface to take heat away....:rolleyes:
Still debatable whether it'll restrict flow or not worI would not call them fins but more like partition. Accordingly to them more contact surface to take heat away....:rolleyes:
Just plug either leh! Sure to be better then your original......Still debatable whether it'll restrict flow or not wor
Good example, but best I like is fighting over the used cooler......hhahhahahhahhahaya la bro...
plug it in and if u dont feel good,put it up for sale in here.
i know people will fight each other for your used cooler.
come to think abt it,why dont u go for the easiest to install and one that reduces complicated joint and possible leak in the piping system?
both will work but the stacked fin is better as the fluid contact point is increased.i dont think it restrict flow.i said this because if u combine the fins,u will get a comfortable space in total for the atf to flow.
just take the radiator for example.go ahead and opem the cap then rev the engine to 3k rpm.does water comes gushing from the radiator?nope,because it has lots of the small water way or fins.
another example.200 people in a room and u ask the to get out using one door,it will be messy.flow is slow and there will be bottleneck at the door.
same scenario but provide 5 door for them to get out.flow is better.
so,stack fin does not affect pressure.
Yeah, that part I didn't understand.Good example, but best I like is fighting over the used cooler......hhahhahahhahhaha
Less one competitor....Yeah, that part I didn't understand.
Ah! If not wrong, you did sell one recently.......hahhahahhahaa:hmmmm:
I don't get it. If I didn't like either one I'd use the one I don't like on my other cars la. Probably the Innova if it doesn't already have a cooler. Why would I wanna sell it at a loss?
