4G93T Club
badturz
574
8
coz misfire problem cant solve. i also want die edi..!!! GRrrr.. checked the whole engine. but no problem at all.. sighz...
chaf
33
1,508
chaf jun here, gary friend from woc...
use Apexi Dual power intake is good...
can last long...if dirty just use air gun to clean the sponge only
K&N so so only...not worth the money
Yea i knew its u....
hehe...
wat happened to ur car...?
mod kaw kaw 1....
thanx for the info....
when free come out TT la....
yashiofactory
328
Badturz - I agree with contreasjun said most probably your tuning bro....ok for the info me im just using those standard GSR injector + standard ECU + standard AIR FLOW + fuel regulator + walbro fuel pump + wastegate 38mm + adjustable cam pulley + TD05 20G but enhance with the E-Manage......still can boost up to 1.4bar previously without any problem but during the E-Manage setting you must make sure that the setup should not to be lean must ngam2 bro.....from the internal all are standard bro....cheers
Chaf - My opinion the APEXI DUAL POWER should be good also and the K & N the performance not bad but the maintenence things quite expensive i mean the special oil for the filter
Wira 3319 - Bro i think your car its time to make so modification from the inside.....i also happen the same thing before my engine kong please check all the connection first maybe theres something wrong somewhere...cheers
Contreasjun27 - There is the picture that your want....im upload it 2nd time 4 u
badturz
574
8
ok bro.! thank you for the advice. i will let u guys know the result after i get the car! i really appreciate it much from u guys.. thank a lot to help me!
contreasjun27
9,000 RPM
9,045
25
subang
bro this picture i see before already...
---------- Post added at 01:01 PM ---------- 6 hour anti-bump limit - Previous post was at 01:00 PM ----------
hehe...
mod kaw kaw 1....
i always free bro..
ask gary out along then sure can find me already
you got my number right
chaf
33
1,508
Ok ok.... thanx for advise....
appreciate it...
Fast fast get ur car done....
i always free bro..
yup... got ur number....
u stay jz beside my housing area there....
anytime bro....
contreasjun27
9,000 RPM
9,045
25
subang
my ride is out now..
but once i rev my car got the trakkkkkkkkk sound..
check tapet is not tapet sound..
damn dont know what sound is that..
sent to my tuner he also dare not to tune my ride scare later engine blow after full throttle..
sigh headache headache
wira3319
258
7
bro, thankz..this problems lately make me headache..its really hard to start in morning or during cold wheather..have to crank 3 - 5 times to start..:banghead:
tis weekend wanna bring to wireman check..hopefully dont have a big problem..:driver:
---------- Post added at 01:18 PM ---------- 6 hour anti-bump limit - Previous post was at 01:16 PM ----------
bro..thats y R n D is need here..and you're the apprentice..we just follow you..:biggrin:
yashiofactory
328
From what you are saying the sound can be from the conrod bro...maybe the conrod bearing or the conrod itself the sound also happen during my engine problem it will sound at the low end of 2 - 4 rpm....cheers :driver:
badturz
574
8
contreasjun27 - Bro do u need running in after change piston? hrmm.. might be ur internal modification.. hehe..
Btw, i have not see my car. sienzz..!
Lazarus
186
16
contreasjun27: your conrod is hitting something or your mechanic didn't do the assembly right. did he check the gap on your rings? did he use the correct size for main/conrod bearing? did he torque everything according to spec? are you using other type of conrod? if so did he check the clearance between the rod and the piston at BTDC and the clearance of the rod with the block?. they are a few factors that needs to be followed to build an engine and what kind of power and reliability you are looking for. just pray u don't have to take everything out again but i doubt that would happen. do update.
contreasjun27
9,000 RPM
9,045
25
subang
well after a few checking..
my foremen say is the tapet problem..
dam the other he sa not the tapet problem..
---------- Post added at 11:05 AM ---------- 6 hour anti-bump limit - Previous post was at 11:03 AM ----------
for me i feel is the car is not run in after a week of dismantle everything..
but now the car is smooth back..
very glad that it run much smoother than last time before my ride enter hospital haha
---------- Post added at 11:07 AM ---------- 6 hour anti-bump limit - Previous post was at 11:05 AM ----------
haha too much info you giving me right now bro..
anyway i just leave it for my mechanic to solve the problem as I'm not free to watch him doing the car bro..
chrissyong
975
14
normally foreman got basic two type,first type is normal repair engine only,second type is like can do any heavy mod car,must be deepend it 1st before mod your engine,coz now got many lao sai foreman...
[H] [K] [S]
1,130
616
contreasjun27 - wah.... u actually leave u car without knowing wat ur foreman doing eh? last time i was like dat also, leavin the car for port & polish, tau tau my lsd got stolen.... ~sigh~ :banghead:
The Marketplace Top Posts
my kenari is facing (i think) engine oil decrease, it is full when cold morning before start the car, and after engine running optimum temp, i shut the car off immediately and remeasure the oil level, the oil level goes down to half, is this normal?(ps. all measurement done at leveled floor) i heard some mechs said that is normal, and kenari engine oil must be measured right after car engine turned off is the most accurate, if low oil level reading resulted from that means engine oil is low...
