is the tuning problem bro..coz misfire problem cant solve. i also want die edi..!!! GRrrr.. checked the whole engine. but no problem at all.. sighz...
Yea i knew its u....chaf jun here, gary friend from woc...
use Apexi Dual power intake is good...
can last long...if dirty just use air gun to clean the sponge only
K&N so so only...not worth the money
bro this picture i see before already...Contreasjun27 - There is the picture that your want....im upload it 2nd time 4 u
i always free bro..Yea i knew its u....
hehe...
wat happened to ur car...?
mod kaw kaw 1....
thanx for the info....
when free come out TT la....
Ok ok.... thanx for advise....Chaf - My opinion the APEXI DUAL POWER should be good also and the K & N the performance not bad but the maintenence things quite expensive i mean the special oil for the filter
Fast fast get ur car done....ok bro.! thank you for the advice. i will let u guys know the result after i get the car! i really appreciate it much from u guys.. thank a lot to help me!
yup... got ur number....i always free bro..
ask gary out along then sure can find me already
you got my number right
bro..thats y R n D is need here..and you're the apprentice..we just follow you..my ride is out now..
but once i rev my car got the trakkkkkkkkk sound..
check tapet is not tapet sound..
damn dont know what sound is that..
sent to my tuner he also dare not to tune my ride scare later engine blow after full throttle..
sigh headache headache
From what you are saying the sound can be from the conrod bro...maybe the conrod bearing or the conrod itself the sound also happen during my engine problem it will sound at the low end of 2 - 4 rpm....cheersmy ride is out now..
well after a few checking..bro..thats y R n D is need here..and you're the apprentice..we just follow you..
for me i feel is the car is not run in after a week of dismantle everything..From what you are saying the sound can be from the conrod bro...maybe the conrod bearing or the conrod itself the sound also happen during my engine problem it will sound at the low end of 2 - 4 rpm....cheers
haha too much info you giving me right now bro..contreasjun27: your conrod is hitting something or your mechanic didn't do the assembly right. did he check the gap on your rings? did he use the correct size for main/conrod bearing? did he torque everything according to spec? are you using other type of conrod? if so did he check the clearance between the rod and the piston at BTDC and the clearance of the rod with the block?. they are a few factors that needs to be followed to build an engine and what kind of power and reliability you are looking for. just pray u don't have to take everything out again but i doubt that would happen. do update.
