4AG BT with CP High comp piston.. compression 10?
meg_omen
421
96
3,028
Home - Klang; O
i think the mech worry about the piston/valve clearance...
you need to check it if you use aftermarket high comp piston...
my mech normally do something to CP piston valve pocket...:hmmmm:
mafia_staff
172
16
Problem identified... need to skim head and block.. thanks guys.. Mechanic admit his fault.. moral of the story- whatever you want to do, make sure you have knowledge or 'concept' what you should do.. adios
mADmAN
1,840
547
3,213
skim head n block???? if ur doing this bcoz ur head gasket is too thick...then u should definitely change gasket instead of skim... that is an irreversible mod...remember that
D7zul
2,697
848
Shah Alam
usually people skim head bcoz of uneven surface
to get more compression ? :dontknow:
gudluck :burnout:
Jac83
164
54
gudluck :burnout:
Yea agree partially, skimming head and/block's purposes are to prevent loss of compression due to uneven surface on either or both the head and block aka to attain the optimum compression ratio. But I don't think u can get more compression from skimming either/both the head and block. Do correct me if I'm wrong:driver:.
mafia_staff
172
16
I have clearance between TDC and top level of head about 3mm, I don't know how this happen... and do you know what is the purpose metal head gasket? from my two cents knowledge metal head gasket is a variable to adjust the compression.. so I shave head and block and counter it with metal head gasket.. do correct me if I'm wrong..
bera
822
229
1,543
ermm...if the block and head not warped no point skimming it...i'd try thinner gasket first...like madman said earlier once skimmed there no turning back...if something happens along the way...you'll be looking for a new block and/or head...
meg_omen
421
96
3,028
Home - Klang; O
how much to skimmed?
wierd coz 3mm clearance is too much coz you're using CP piston...:confused:
if i can remember; only skim max 0.5mm if using 0.8mm TRD gasket...
this is with Toyota 0.5mm oversize piston...
if more than 'engine tak sedap'...:hmmmm:
1JZtezza
371
42
if i can remember; only skim max 0.5mm if using 8.0mm TRD gasket...
its been many years but 8 mm gasket??
Devil in the details...but are the CP pistons supposed to be paired with their rods.. check the pin location first..just my 2 cents mate...no experience with CP stuff or 3S engine!
---------- Post added at 11:56 AM ---------- 6 hour anti-bump limit - Previous post was at 11:25 AM ----------
Attached CP catalog
http://www.cp-carrillo.com/LinkClick.aspx?fileticket=yrZ5T5U6dHU%3d&tabid=82
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
errr..have you check the piston deck height/wrist pin height comparing them to original piston? :adore:
cuscostrutbrace
987
62
3,028
yes bro..maybe compression ratio...static compression different.....:driver:
Compression ratio and static compression is same thing..
---------- Post added at 09:17 AM ---------- 6 hour anti-bump limit - Previous post was at 09:08 AM ----------
chinozie
Very Young Member... :D
3,429
170
5,163
Damansara
4age20v.blogsome.com
Soo what's the current update ?
mafia_staff ...are you to increased the dynamic compression...my old engine with 0.5mm oversize piston, I've manage to get a value of 14... :D
The Marketplace Top Posts
everyone knows dish cleaner will dry up our clear coat if we use it as car shampoo but certain people might not know. i use to do that when i was 18 on my wira. as long i find its clean, who cares? :biggrin: today, as i know what is detailing i never use dish cleaner to wash my car anymore but my mom did. she use dish cleaner to wash her car for like 4 years alredi since she got her car but sometimes i help her wash with car shampoo of course. here is the result after for so long, and also...
