20v Knocking Sound When Accelerate
me2kimi
717
276
1,563
Puchong
Sorry bro we cannot. Our 4age use OBD1 port, those gadjet are meant for OBD2 port
6UE5t
6,000 RPM
6,756
1,300
Like Dayline668 suggested, that symptom is more like engine knocking/detonation sound, so need to retard the ignition timing and check/adjust your air/fuel ratio (lambda value) if it's too lean.
plank
75
10
1,508
IPOH- SETIAWAN
go to mechanic.. check ignition timing using timing light...
last week my engine knocking.... check ignition timing too retard,,, set to 10 degree.. increase little bit fuel pressure = knocking gone
meg_omen
421
96
3,028
Home - Klang; O
4age 20V is not obd2 not obd1...
it's using much older type...:hmmmm:
you need Toyota diagnostic computer for that...
i think for the cost of this... you can get new Vios...
tonyops
249
17
518
Sarawak
This is a great topic. One question, if air-fuel mixture is rich, will it cause knocking ?
Mine knocks on RON97 especially in the hot afternoon, with FPR set to 2.8 bar idling, stock internals, trumpet intake and aftermarket exhaust system.
Can anyone help?
Dayline668
1,810
492
1,683
Can anyone help?
Richer AFR will reduce knock but not when engine sucking hot air in, same N/A or turbo. Best solution is reduce timing or go meth.
bera
822
229
1,543
if AFR too rich...some fuel will left unburnt...prolong use will cause unnecessary carbon deposit...the effect can see straight away by looking at your spark plugs...
levin818
1,260
321
3,183
Shah Alam
Ken's problem solved... Ign timing >15deg, ISCV clogg, Knock Sensor disconnection.
Ign timing set too high because if set at 10deg the car cannot idle.
Knock Sensr disconnection because the car knock crazyly and the mech trying to check the sensor but mistakenlly broke the connecton.
All of this is because the ISCV cogg!
And the poor mech didnt know how to solve it, but insead created another 2 problems.
KenDiriwan
1,283
225
3,163
kendiriwan.multiply.com
Thanks Sifu Wong you are really a passionate person and the way you work is magical, was really gan jiong when the car couldn't start last night plus i was having light fever.
First impression, me and my brother thought we found ourselves some BMW tuner hehehe.
After settle all the fault item. I will start loading up performance item :biggrin:
Hi all here.... I just want to ask for experience on brake pads. I was quoted 160 for a brand Mintye and 300+ for bendix on toyota mr2 2 pot. Im on a budget so im more inclined to go for the mintye. Any experience on this? Is it ok? Because i got nightmares with cheap bad pads b4. Just for city drive no track. Or else, any recommendations?
