4A-GE 20V Knocking/Pinging
EFN
1,294
19
Batu Caves
As most of us have already known, 4A-GE 20V specially ST are notoriously easy to experience pre-ignition problems or more known as knocking/pinging - specially when the AC is on.
One of the reasons is that 20V are designed to run on Octane Level 100 - so the system are optimized to run Advanced Ignition Timing. But in Malaysia, with RON97 and sweltering hot operating condition, Pre-Ignition are bound to happen more frequently.
Other cause for Knocking/Pinging are Lean Condition due to the following factors:
- Injectors clogged
- Fuel Filter clogged
- Fuel Pump weak
- Fuel Pressure Regulator weak
- Vacuum leaks
And I found another one cause that I have overlooked for a very long time -
PCV Valve slightly leak.
- Yes, after troubleshooting my 20V fuelling gadgets, I have decided that none of them are the real contributor to my engine's knocking problem. So I began looking elsewhere and just today I decided to experiment with the PCV Valve which has been "senget" for a very long time and I never bothered to fix it up before. The Oil Seal surrounding the PCV Valve were somewhat worn out (13 years old engine - what to expect huh) and this has forced the valve to lean out exposing a very tiny bit of gap which might have allowed some air to seep into it. Fixing it up is easy, just take out the whole PCV Valve and wrap a healthy amount of Plumbing Tape around the lower socket and snug them back in. Check that the PCV hose itself does not have any leak and reconnect them all. Upon testing out my car, i immediately noticed the difference as my 20V does not knock that easily again when the AC is on, and it took me only 15 minutes to fix the problem! - should have done this long-long time ago.
So you guys 20V owners out there, go ahead check your PCV Valve, if it is a bit senget and start to expose a tiny bit of socket, better get them fixed.
Hope this helps.
Acoustic
1,295
52
Hong Kong
www.my-acoustic.com
PCV Valve?
got picture or not?
EFN
1,294
19
Batu Caves
This one laa fren - In red circle. The PCV Valve shown below have just started to go senget and can see the red lining - possible leak there.
EFN
1,294
19
Batu Caves
This one in Yellow circle have still intact PCV Valve seating. No leaks
TRD16v
1,802
5,138
Tokyo, Japan.
EFN,
how about 16v? can u help me to rectify it? Thanks :) for one second i tot u got new product again.. hahaahaha... :D
Regards,
Mike
Acoustic
1,295
52
Hong Kong
www.my-acoustic.com
I see, will play with it and let you know later :) btw do you have vacuum gauge in car, what are your readings?
EFN
1,294
19
Batu Caves
TRD16v:
Naaah, jsut sharing some info on my discovery hahahaha.
I guess this applies to any car that have PCV Valve. It's very easy to check. Just look around the PCV Valve stem and ensure that it is not plugged in akward position.
Acoustic:
Nope I don't have any Vacuum Gauge ye hahahaha
levin818
1,260
321
3,183
Shah Alam
EFN,
Great discovery :lol:
To add in my little experience: if the PCV sudah clogged, your engine will give you white smoke form the exhaust. So if next time see white smoky at the back, dunn just go spend big money to open up your engine. Check your PCV valve condition first. It could save u some big bucks.
cynicks
424
PJ
Originally posted by TRD16v@Feb 7 2005, 23:06
EFN,
Regards,
Mike
Eh ! That first engine looks VERY familiar... is it mine ?? Is my PCV senget ah ? Aiyo... got problem neh... must ask master EFN to come liao again. hahahahah let me try it to fix myself first...
Acoustic
1,295
52
Hong Kong
www.my-acoustic.com
Wah, now got allot of people panda top grey + black :)
adian
395
57
3,028
PJ
www.the-yeins.com
Good post EFN. Any airleak into the intake system is always suspect.
More interesting tho is how highly tuned and setup the 20v is. A bit too little juice or a bit too much air and whoops.. why not simply retard the ignition a bit to compensate and save the grief.. albeit at the expense of one hp or two..
EFN
1,294
19
Batu Caves
Yep my fren, that's your AE111. No worries. What you can do is just buy one RM1 Plumbing Tape, loosen a bit the two bolts that hold the injector harness (to make room for you to take out the PCV valve), take out the PCV Valve and wrap a healthy amount of plumbing tape around the stem. Plug them back in and ensure that they fit in nicely. When you reconenct the PCV hose, pay special attention again not to allow the hose to tilt the PCV Valve...good luck!!!
EFN
1,294
19
Batu Caves
hahahah quite true. But me guess that my hands are tooo reluctant to retard the timing when it feels sooo good running at 16+ Degree Advanced hahahahaha.
Ray
339
EFN... what is diff between PCV Valve and Breather? hehehhee me do no laaa...
my breather got lot of engine oil come out into intake .. so i pulled out the hose... and changed to long hose come out as a wasted oil...
is it ok?
p/s: mine is 16v :( not 20v.......
i'm wanted to paint my car before CNY, any recommended place to go for? cheap cheap one and quality not bad also la...
my base is white colour, so i need only to paint a layer of white onto it, maybe 2k white, champion white or the white colour like DC2 one..
how much does it cost? some quote me Rm1200, some above RM1500... 1200 is ok, but heard workmanship is so so only..
anyway, my budget are around Rm1.2k... if can get...
thanks zthians :)
