balancer shaft removal
jameswwt
1,127
78
1,648
Hi Spuzzle,how is yr engine rebuilt after yr burnt rod bearing? Any crucials areas to look into while doing the rebuilding (replacing the crankshaft,oil pump,etc)
Mind to share?
spuzzle
741
9
Kuantan / Perth
james, i replaced with evo block but it lasted for a while only...piston ring gave way...then i rebuild my vr4 block...vr4 block done but havent install yet :proud:
jameswwt
1,127
78
1,648
wat!!! omg!!! did you change yr oil pump, crankshaft & oil cooler when yr rod bearings toast?
jameswwt
1,127
78
1,648
hi spuzzle,is it necessary to replace the balance shaft overhauling the engine??? What is the benefit of replacing the shaft? mind to share?
spuzzle
741
9
Kuantan / Perth
james, it is not necessary to replace the balance shaft...in my case, the shaft bearing broken then the shaft badly scratched so i have to replace it...the broken bearing ruin up everything in the block...what i did now is remove 1 of the shaft ( the one run by belt ) and machine the other shaft...will update u once i install the fresh block :proud:
jameswwt
1,127
78
1,648
thanks for sharing spuzzle as 1 of my friend recently also rebuilted his evo 6 due to rod bearing problem...but after he took out the balance shaft his mech and him found out its hard to put in back in place...Dont why? So scary? Btw,will a burnt rod or main bearings affect the balance shaft?
Sorry for asking much...
Btw,it will be very crucial to change yr OIL COOLER yaa for the sake of long term durability...
chrissyong
975
14
told u last time already,better rebuild your vr4 block,evo stock piston ring and piston and con rod like tofu fa man,whatever u gain the real exp,good luck
spuzzle
741
9
Kuantan / Perth
i would say burnt rod/main bearing wouldnt effect balance shaft unless the debris flow through the oil and get to the shaft...its good to ask than to learn the hard way, we are in forum to ask and answer...hehe
last time i couldnt find vr4 internals to replace my crank, oil pump and balance shaft until i bought a complete engine...by the way why dint see u online msn for so long?
jameswwt
1,127
78
1,648
Thanks for sharing Spuzzle....Where you do yr overhaul? Just wonder do you know any shop can do chemical cleaning to the head & block?
chrissyong
975
14
lol get sick very long time,i thing got 2 month random non stop sick,old story already whatever i cure already....
spuzzle
741
9
Kuantan / Perth
i did in kuantan...not sure where can do chemical cleaning...i suggest u better spend the money for port/polish
Question : This balancer shaft works as a harmonic dampener? Or...?
these shafts counter balance the vibration
Ok, so by this logic, if say the whole engine was completely balanced to the 3rd decimal point (just hypothetically speaking) would it still need this counter balance shaft? What vibration does it counter? Where is the vibration from?
Tips to improve Fuel Economy
(Applicable for all vehicles including Cars, motorcycles, trucks, bikes etc)
Here are some very good tips on improving your vehicle's Fuel Economy / Increase Fuel Efficiency / Mileage. You’ll be amazed with these techniques and tips which seem so simple yet improve Fuel Efficiency drastically. In view of increasing fuel prices it is becoming more and more prudent to use them.
Use your gears wisely
Try to switch...
