Vafc ii
dvino
92
10
1,508
Morning Guys, :wavey:
I was told by a mechanic that if you install the VAFC II you need higher compression pistons.
The reason behind this is that if one adjusted the VTEC trigger point to lower RPM let’s say 5k then when VTEC open on that RPM (5K) you will see a power dip before gaining back your power. He says not enough compression in your engine. I don’t get the clear picture on this scenario.
Obviously this is s disadvantage to the driver as he sure will lose to the other car that trying to asap him.
Any opinion/facts from you guys regarding this? :hmmmm:
Vagabond
1,731
53
1,648
the mech who told you that you need higher comp pistons to install vafc2 is an idiota :rofl: ask him where did he do his training? Coffee Bean ah?
v-tec buka early, doesnt mean got power la.
otherwise all the non-type r engines open v-tak @ 3k or 3.5k rpm .... like that sure asap all the ITRs and FD2R's liau la ....... *actually, those 2.0 i-vtecs are not even actual vtec engines.... so let's refer to them as V-Tak from now on :rofl:*
it's all to do about the power curve, if not mistaken.
but don't take my word for it, what do I know? after all ..... i only use the car to pull women!!! :rofl:
dvino
92
10
1,508
hi bro's
thanks for the inputs.....i guess that the dump ass was trying to con me to buy the VAFC2
daimn lucky i didnt buy :banghead:
dcloo
1,784
17
kl
hi bro's
VAFC II = Junk for i-vtec engine
only buy management its allow adjust variable cam phasing (hondata,AEM EMS,F-con Vpro,Autronic,Motec)
Vagabond
1,731
53
1,648
on a seperate note. to eliminate the 180km/h speed limit, would a RSM be sufficient? or is there any other "all in one" to buy?
yes, the rsm does bypass the speed-cut.
but it attracts thieves like nobody's business!!!
Speed-cut <<< RSM <<< Pencuri :biggrin:
i need some simple tuning for my carburetter engine
anyone here can help or provide tuning ?
my budget is around rm400 max
quite low ,
