Install trumpet inside plenum. Any difference???
pcmoddingmy
1,147
101
www.pcmoddingmy.com
Regarding the sound... i didn't feel much difference if installed inside the plenum, but the type of intake air filter used also plays an important role. If using HKS mushroom filter, I think the ITB roar will be louder. I myself using Apexi dual funnel, sound wise not much difference after swapping out the rubber OEM trumpet to SS trumpet. However, remove the plenum and you will be an immediate crowd pleaser. ;)
Trumpets aka velocity stacks doesn't necessarily increase HP, its more of a responsive improvement thingy. Just to note...
j_l200s
338
74
3,028
well, open trumpet is nice but it'll 'choke' a bit when your rpm is around 3-4k range. but after that... ;)
don't floor the throttle when u are around 2-3k rpm. slowly press down the throttle. when it passes 3.5k-4k rpm then only u floor it. u'll be amazed. :D
1JZtezza
371
42
Its not so much the trumpets but your cam and AFR.In stock mode the BT VVT kicks in @ 4400rpm but with the 272 cams the intake opens about 20deg earlier so you got to retune and that should take care of it.
20V Trumpeteer
252
130
Kedah
Regarding the AFR,how to adjust it?coz my car seems to hav a misfiring sound and quite frequent there's a 'fuel-cut' feeling eventhough I'm not pressing till the redline....does it bcoz of the AFR or something else...my car really need to meet the 'specialist doctor' bout its illness
meg_omen
421
96
3,028
Home - Klang; O
this is actually symptom of O2 sensor getting faulty...:banghead:
j_l200s
338
74
3,028
owh really?! hmmm, i was a bit suspicious when i did that O2 sensor test. multimeter works fine (moved up when i press throttle and down when i released throttle) except when i maintain the rpm @ 2500, the meter will be idle in the middle. It didn't move more than 8 times in 10 secs. actually... it doesn't move at all... LOL :banghead:
now the hard part, where to get a new/working used sensor? :confused:
j_l200s
338
74
3,028
yup, quite pricey...
do inform if you manage to secure the item with a good price...
coz many from Club4AGE changed to Bosch LS05... however i've been quoted at RM469 by the Bosch dealer...:banghead:
related to trumpet... just to share not promoting...
Drift.com.my ~ View topic - High Quality Aluminum Trumpets.
good bell-mouth shape...:biggrin:
Just called up an authorised Bosch distributor in Butterworth. I asked him what's the model and he said it's for universal use. he didn't give me the model number :banghead:. He said any car can use. the kit comes with application chart and wiring diagram. He said as long as u hook it up correctly the 4 wires, then it should be working. No return after buying cos i said i'm a car owner (customer), not from any spare part shops.
the price he quoted me for a brand new one is RM350.
anyone interested?
meg_omen
421
96
3,028
Home - Klang; O
anyone interested?
remember if using Bosch LS05 (yes it's universal)... you need to put a new 'bung' to your extractor... coz this is not like ori Toyota O2 where there's a flange instead...:banghead:
good luck...
j_l200s
338
74
3,028
is the 'bung' same as the one they used to cucuk in the wideband sensor during tuning?
sdil_trdtoms
381
wat is the diff between short trumpet and long one? any comment?
The Marketplace Top Posts
Dear ZTHians,
My proton wira with 4G15 engine has a leak. I suspect it is due to gasket problem. I have got two quotes from mechanics and one quoted me RM5xx including ordinary service + repair valve and another quoted me RM1k because he said he is unsure what other damages are there.
Well this problem has been there quite some time since my car overheated and blew its head. A new head from chop shop replaced the blown one but perhaps due to poor installation, oil leaks and I wasnt...
