Need some Help , Advise and Suggestion
ckwanloong
160
11
throttle body sensor....it cannot catch the idling sometimes like asma...then engine dies off!
Vagabond
1,731
53
1,648
i think you meant the TPS la , throttle position sensor.
anyway CKwanloong , also check your MAP sensor readings .... sometimes car asthma cases can be caused by failing map sensor as well :biggrin:
yaw90
299
14
hmm how come i feel my clucth become lighter ??
izit time to change it?
2day i drive my car and i feel much lighter than the last time and not smooth when masuk gear..
fuazuri
99
1,508
Yaw90 : after a few months of clutch pumping, ur leg muscles have become stronger thus when u press the clutch, feels lighter. Juz my 2cents.
Apa la aku mengarut ni. Selamat malam.
Vagabond
1,731
53
1,648
what's the mielege on your car???
yaw90
299
14
but not only me realise it.. the workshop worker and my fren drive my car also feel it..
my car mileage is bout 56k
ckwanloong
160
11
ic...thanks alot...but these sensors...tps..map..o2...always kenal rosak leh...these problems come after i change my throttle body...sometimes it dies off then difficult to start !! damn hate this happened...when i was the 1st at the T junction!!those cars~~horn me like crazy frogs and lots of "things" came out frm their mouths !!
Vagabond
1,731
53
1,648
bro ..... that happened to me just this morning !!! :biggrin:
ha ha , relax ..... what you do , when it's difficult to start , as you're turning the ignigtion, just pump away at the accelerator pedal , it usually helps to start the car.
this issue is caused by a faulty MAP sensor .
---------- Post added at 10:51 AM ---------- 6 hour anti-bump limit - Previous post was at 10:05 AM ----------
well .... it could be:
a) pressure plate / clutch plate worn off
b) one or both the clutch pumps (especially their internal springs!) defective
c) clutch hose leaking
d) bush at the top of the clutch pedal adjusted wrongly
........ unless your leg become super powerful, it should be one of these issues :biggrin:
ckwanloong
160
11
how abt u prasath?? heard tht if put a k-pro in can gao ding this o2s issue??
prasath_5338
1,131
19
If im not mistaken you can disable the o2 sensor with Kpro so that you're CEL wont appear . But then you're FC will be higher. TPS and o2 faulty sensors are common. Just replace them.
I am always curious that whether this X1R product is workable. Any master can share with me their experience or comment??? Thanks
