VTEC is to allow good power at high and low RPM. It requires certain pressure before engaging. You can cheat by using pressure sensor bypass, but vtec won't engage smoothly if set too low, nor would it be good for the system.
Afaik, the spoon vtec controller came out when engine management was very expensive, thus it's a less expensive method to change vtec crossover.
I think most management have this, so the point of installing a vtec controller is not practical, unless that's your final mod, and you don't plan on doing anything on the engine anymore, just daily driving it and changing the vtec point earlier or later, depending on how you want to drive.
Most cars cannot engage vtec below 4.5k, some not even below 5krpm due to mapping, oil pressure and other factors.
I ran a vtec window of 5400-6000 on my old b16a using hondata, low throttle vtec engage 6k, and full throttle vtec at 5.4k. Full throttle crossover decided by doing low and high cam runs on dyno. Should be 5.5, but set earlier to still get that vtec kick due to that torque dip, or not it become smooth, and the only way you know the vtec engaged is through the exhaust sound.
Some people think if vtec makes the car go faster, then it should make it better on the low end. There's a reason why it's called a hi cam and low cam, heh. Too long to explain about cam duration, overlap & lift. Just read about them and you'd understand how 1.6l can make 200ps@11k.(spoon) and how a normal b16a can get 170ps @ 7.8k
Toda killers would kill low end power and make the car unsuitable for daily driving. The advantage is that it converts the rocker system to roller rockers so can run really aggressive cams without wearing the rocker arms and timing belt too fast. You won't see killer cams coming out for the K20A_R, because they're already on rollers.
Low end power is important on daily driven or street cars, but VTEC high cam is not the way to get them. I'd say to get better low end power, need to.
a) get the engine tuned, even if it's just a b18c with light mods, and tell the tuner you want the low end power.
b) don't go running 2.5 inches exhaust piping on honda 1.6/1.8
c) don't go bumping fuel press to 4bars just because a lot of tuners do it before tuning 18c.
d) insert more here. :-)
Got to realize that no matter what we do, we can't beat a short rod engine's torque at 1-4k, unless we go higher displacement/compression.
