What are these meters for
r0yEE
1,775
9
how to differentiate cap ayam man???
Bump: how to differentiate cap ayam man???
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
water temp, oil pressure, vacuum gauge, rev gauge
forgot to mention, i bought a boost meter by autogauge. Got the 90 degrees smoke series
sorry for the blurr pics...
got it for RM150. tested on road shows that my peak boost reading at 0.8bar....
went to my pomen, we swapp it wif my pomen's trusty omori.... the reading oso read the same...
went thru a lot of bumps and potholes but the reading still stable.... just concerned abt the hose used... its the clear one like aquarium always use....
most ppl i asked, autogauge arguably the best budget meter around..... grown from autometer-imitating-cap-ayam to a pretty solid brand...
maybe it suits u as well? after that if got budget then go for those branded meter...
p/s: for ol skool car such as yours...omori is good.. solid japanese brand wif retro look
r0yEE
1,775
9
where to get omori meters? any suggestions papa?
Bump: where to get omori meters? any suggestions papa?
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
ENEOS got.... but the price slightly lower than hks/apexi....
r0yEE
1,775
9
where is ENEOS?
i only saw one in kuchai lama..
Bump: price lower is good:rofl:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
where is ENEOS?
I saw at ENEOS One Utama... there's 2 other ENEOS, Kepong and Bkt Tinggi
yep..... the price is lower... but still out of my reach lor :slug:
r0yEE
1,775
9
out of your reach as in?? too expensive?
if expensive for you, man sure thing it will be for me:banghead:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
for me, my budget not more than rm200 per gauge... can't remember the omori price but more than my budget....
that's why i'm recommending the autogauge... well within my budget.....the boost meter cost me rm150..... if i can stretch a bit, sure i grab the autogauge stepper motor series....defi-like :biggrin:
before this, i've considered hafkat meter such as apexi, blitz, hks etc which within my budget but too impatient to search at hafkat :slug:
r0yEE
1,775
9
but autogouge not so accurate man.. the one i'm using now.. the rev meter not good..
the response is slow bout 1-1.5 sec
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
really? mine is quite good....well not as fast as my pomen's but not as slow as what you described
r0yEE
1,775
9
that's why.. which range are you using?
i'm using the old range.. which is a white and red LEDs
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
using the smoke lens gauge series 90∘scale 52mm
but I'm only using boost meter... not sure about the other
r0yEE
1,775
9
i'm using the same one as your papa, but mine is RPM meter.. ishk..
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
So Roy, haven't decided on what meter to buy? Wish you all the best. Try to get meter with stepper motor. Autogauge also have I think or search in marketplace there's some forumer selling
Hi all,
I'm planning to diy a MegaSquirts V2.2 to my saga lmst year 2004 to convert from carburetor to EFI system.The question is the throttle body,injectors,all the sensors,fuel pump,distributor,intake manifold need to use from a set of parts from 4g15/13 efi system?All the sensors from 4g15 efi system can b work with megasquirts or not? Also how much do the hardware that i listed cost? pls give some advice n comments thank you..:biggrin:
