What are these meters for
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Bump: yo papa, kancil's arrow dynamics are like a block trying to go fast.. for a 120Y it's whole lot of diff man.. its dynamics are just built in..
during my NA days auto transmission summore... i've used adjustable (front only can adjust) coilover kit from GAB malaysia... at that time, i've set it to lowest point and have to change camber setting to negative (a bit)... at that time 110kmh still feels stable
now after swapping to turbo, i've also swap into L5 ori suspension all around (getting old...wanna have comfy ride :slug: )... now it feels wobbly even after 100kmh...maybe the increase ride height oso increase the lift...
kinda ironic :hmmmm: ... if paired my old GAB wif current manual tranny + LSD....sure handles like a dream...
papa, that time I was still a student. Going at more than 140km/h on a van...the feeling is actually not that scary. I'm not boasting my balls here but it's feels normal. The van was not shaking or swaying i just hold the steering straight and not do any big moves.
forgot.... kancil's much lighter than a van... silly me :adore:
ryanz88
25
btw..i juz wanna know ..i've change a auto meter water temp gauge
i wanna know watz de normal temp for de gauge?!coz if i on de aircond,de temp goes 80-90 degree,but if i off de air cond,de temp some sometimes vil go up 2 90-100 degree!!
normally watz de problem??:confused:
pioneer411
i think is the FAN problem.. when u open aircond the fan will start then colder for the radiator.. and maybe the radiator fan rosak liao.. pls check :biggrin:
Bump:
helllo guys..how can i improve the power window system in proton wira??..anyone can help me??...
wrong section bro...
r0yEE
1,775
9
yo paan, wrong forum man.. go post a new thread or something..
ryanz, more or less is your fan. usually you engine will heat up when your air-cond is on cause it's running more. but yours is the other way round.. better go check it out..
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
thkz bro...if de fan got prob,normally how much??
ryanz,
Your fan is not faulty. It's normal for the temp to go higher with the AC off because when you on the AC the fan will turn on and off more frequently. You can actually feel it. When the AC compressor engage the fan will turn as well. Then when the AC compressor disengage the fan will stop. How to test your fan working or not is by turning of the AC then let the engine run. When the coolant inside the engine side reach the temp that could open up the thermostat then your fan will turn. When this happens, it means that your fan is working fine. If your thermostat open but your fan not running means that your fan is kaput or maybe sensor spoil already.
shiroitenshi
3,676
170
Just want to add,
Electronic sensors ARE WAY MORE EXPENSIVE than analog meters. This goes for replacement sensors, and the initial price of the gauge.
Personally, I prefer analog meters, but the new electronic meters are close to the response time for analog meters, and they look better too, so depends on budget if anyone wants to go analog or digital.
Also note the length, longer is better as you can hide the cables from view.
Bump: Just want to add,
r0yEE
1,775
9
now who am i going to get this meters from?? it's either too expensive or not stock.. ishk...:banghead:
Bump: now who am i going to get this meters from?? it's either too expensive or not stock.. ishk...:banghead:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
what meter u referring?
r0yEE
1,775
9
water temp, oil pressure, vacuum gauge, rev gauge
De'WhiteCrusader
31
c ur budget 1st and then window shop 1st wat kind of brand and look u like.. but dont buy the 'cap ayam' brand k..:biggrin:
Bump:
to all sifus,
1st of all, my car only done minor upgrading such as exhaust system, intake manifold, and using ECU ralliart .
here the situation:
1) been use E9 almost 1year and never pump 95 only 97. my fc is about MYR 50/90km:banghead:
2) last night i decided to pump 95:thefinger:. what is the cons of using 95 on mivec turbo?
please advise me.
Tq:driver:
