Performance on Satria Neo ?
liz@rd
492
57
so u have done
1) 4-2-1
2) spark plug cable
3) knn drop in
4) throttle body response
well if i were u i would go for
1) open pod
2) 4-2-1 or 4-1
3) full piping
enough for the moment , spark plug cable , iridium spark plugs , aluminium fuel rail , acp , lcp all can put aside 1st.
then go for engine management ... fixed ur a/f ratio ... by then only start going for internals ...
surbo , micro compressor , air compressor , etc etc u can try but @ ur own risk ... aherm ... my 2 cents only , anything wrong dun shoot me ...
Voxism
41
thanks for ur comment skywalker..
FPR = Fuel Pressure Regulator , ACP = Adjustable Cam Pulley
yup i did my rebore trottle body today.. very good response especially during 2k rpm start..
intake manifold haven do it.. budget problem..
ya.. if getting the FPR i will buy the full set including the dummy cap.. not sure where can get it.. they told me links have it..
Bump:
so u have done
1) 4-2-1
2) spark plug cable
3) knn drop in
1) open pod
2) 4-2-1 or 4-1
3) full piping
e manage i cant afford for now.. and i wan to do some basic mod 1st to improve my low end rpm..
those surbo those i tried before.. useless for me..
Bump: ------------------------------------------------------------------------------------------
So the next step i should go for Fuel Regulator Pressure rather than Adjustable Cam Pulley rite?
okok noted guys!
but before that, i book some stuff from my friends. Give some opinion pls.
1) Exhaust Mid Section = 2" Piping with 2 bullets ( Custom by Jian Hang )
1 of the bullet is customed for Auto Transmission by Jian Hang, and 1 more is normal bullet.
2) CRV Spark Plug Cable custom for neo = they told me the best cable for response
3) Everco S Flow = tested once, main reason i get this because the sound is not loud.
so this is my coming mod..
for planning mod = Fuel Regulator!
Current Mod under my bonnet !!
1) Volker Iridium Spark Plug
2) Trottle Paddle Adjusted
3) Trottle Body Rebored
4) K&N Drop In Filter
5) Larger Snorkel Inlet
6) R3 4-2-1 Extractor.
so far the pick up already satisfied enough !!
Yong_5290
3,637
49
Klang
hotmail.com
wan feel lighter go 4 lightened crank pulley...lighten the flywheel a bit...a little but enuf...too much hard 2 climb hill
Yong_5290
3,637
49
Klang
hotmail.com
oh sry...din c auto...then just go 4 the basic setup...4-2-1...piping...muffler..CAI..air filter..drop in better...retune ecu
Yong_5290
3,637
49
Klang
hotmail.com
hmmm...stock car mostly comes running richer in air fuel ratio...so by instaling a FPR u can slighly tune 2 get a better air fuel ratio
an AT oil cooler is not bad but i think wit good maintainance n good AT oil...its not really needed anyway...its not like a AT will go into sepang
achmedrauff
255
5
www.onlyinmalaysiamah.com
Dude... based on my experience of owning a 96 1.6 Satria I have changed the AT twice~ plus don't expect to own a 1.6 2 door hatchback to be driven at grandma speeds all the time. So for those who practice spirited driving half of the time the oil cooler could be a sound investment.
rex79gt
742
98
Ngiao City
i;ve learned sth
juz turbo charge the campur engine then it can pwn many cars adi :P
andrew lsp
85
1,508
k&n drop in with larger air snorkel
bosch fusion spark plug
unichip q+(dastek)
throttle booster(dastek)
shell helix ultra fully syn(5w-40)
fully syn transmision for mt(75w-80)
fully distilled water mix with coolant 60%water 40%coolant
Hi guys, Can i replace MYVI electronic meter into Satria??? Anyone done this before and how many wiring should be modify it? I have saw it fix in GTI. Pls give some comment. Thx!
