Carburetor Section
Darth
368
2
3,018
Selangor
dis thread still alive..............fuyoooo...........:adore:
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
4g91 carb not many tuners around... coz japan mali carb and it is not popular...
why ur proton using 4g91 carb at the first place??... where ur oem carb??..
yewjunyan
108
for the Saga, my original carburator is still under my bed...i m thinking of changing back to it if there is no solution for the abovementioned problem...
proPIPING
1,077
5
one more systoms i notice on this carb is that when i deccelerating, off throttle, i can hear the 'poping' sound from the ekzos paip...sounds like a lean poping to me...but i still not clear how to solve the hessitation....jerk everytime i press the gas padle really makes me to loss confident of driving this car...sifu pls help me to teach this naughty 4g91 carb...thanks...:itsme:
poping may cause from the timing that too advance...check your timing at the workshop using timing light...normally it will be 10 degree at 850-1000rpm....
angelic_ryder
59
hi, i'm having some prob wif toyota se 4af carb. (standard carb)
1. the car doesnt feel rite (b4 this felt really torquey n surprised wif d pwr even 4 stock engine )
2. got strong fuel smell from the muffler
3. Carb leaking
4. spark plug black color (i think 2 rich gua)
Things that ad done
1. carb cleaned using wd40
2. new air filter
3. new spark plug
4. new petrol filter
5. noting wrong wif spark plug cable
6. did tuning ad (many times actually)
Went to a few diff mec (min 4 -5), all saying diff things. These are the probs listed by the mecs
1. Carb kong ad (hav 2 chnge cuz smthing to do wif butterfly not opening)
2. engine compression out (need over haul)
3. change 2 4age
4. old car ad ma, so normal laaa....
im seriously tired wif all this.. can anyone suggest or enlighten me on wats d real prob.. is it the carb or the engine?
any replies will truly b appreciated...
fstr
7,935
954
Sahara Desert
2. got strong fuel smell from the muffler (change your fuel line rubber, change your fuel pump, change your petrol filter)
3. Carb leaking (check all the hose to your carb, from petrol to air)
4. spark plug black color (i think 2 rich gua) (yeah, very rich and advance timing)
Things that ad done
1. carb cleaned using wd40 (waste money and time, use ur hand to pump & tarik d throttle 9 9)
2. new air filter (no difference)
3. new spark plug (use back normal plugs, no.5 or no.6. dont go use high end 100 buck per stick kinda plugs)
4. new petrol filter (then it must be your fuel hose rubber located under/behind your trunk which is the fuel tank)
5. noting wrong wif spark plug cable (check your distributor and ignition coil)
(this one big possibility)
(no such thing)
3. change 2 4age
(i also can say that, in fact say it to many ppl, many times):biggrin:
(mine older then yours, so how??)
replied in bold :hmmmm:
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
3. Carb leaking
Things that ad done
2. new air filter
3. new spark plug
3. change 2 4age
which part of ur carburetor is leaking??... i suspect bottom of ur carburetor... if so, air will leaks out... less fuel, more air, rich air fuel ratio....
u clean ur carburetor with wd40 regularly??... wd40 could be the cause wearing out ur carburetor gasket...
proPIPING
1,077
5
3. Carb leaking
Things that ad done
2. new air filter
3. new spark plug
3. change 2 4age
is't the car difficult to start in the morning?
angelic_ryder
59
bro fstrader,
thanks 4 d lengthy advice... first time using carb engine, so really2 noob... bro, bout the compression thingy, this is wat the mec told:
"Since compression out, spark plug cant burnt fuel effectively, hence the petrol smell.. he also say no prob wif carb, spark plug and cables.. so, confirm compression prob "
will check and try each of ur advice to solve the problem.. if cannot, i think hav 2 come to ur place la... which part in kepong? near mitch's place ar??
bro skywalker,
yes, u r rite.. leaking at the bottom... but the mec i go to says its not the gasket.. at first i tot gasket bocor, but he say carb hav 2change.. actually d mec use wd40 to clean d carb..
bro propiping,
nope... touch wood.. until nw, no problem wif morning starts..
ps: thanks for all d advice... hopefully my issues can b solved asap.. Really loving CARBS.. Tats weird especially in this era... HAHAHAHA
proPIPING
1,077
5
carb era will be here always, we never forget our roots :biggrin:
wanna cry ar remembering that time...still study,saving half of the money given by my parent to mods my proton knight...buy webber dcnf40,pnp,bigger clutch and etc...always not enough money that time but the spirit to mods the car finally make me archive what i want...:bawling:
The Marketplace Top Posts
Any sifus here willing to help?
Engine is a Mira L200S. Bought a new battery and crank it up. Response on the engine is slow and not revving fast enough. Multimeter reading is around 11-12+ volts.
Revved the engine and the reading stays at 11-12+ volts also. But when I disconnect the battery or the socket at the alternator, either one, the engine revs normally. What I can see here is there is only output for the battery and no input. When I connect the socket/battery back again, the...
