difficult to start my 4AGE 20V SVT
shizilki
61
1,508
terengganu
hello to all bros,
plz help me with this, my engine having difficulty to start. i've replaced all 4 spark plugs, new plug cable, service my air filters but it still difficult. can anyone help me plssssss.......:banghead:
wilm3
500
29
checked ur battery and starter motor??
AE101-Wong
4,448
113
ur air box hose got pecah anot?
shizilki
61
1,508
terengganu
battery 1 year old already, starter motor i think still ok. N one more thing, after each succesfully start, it smell like gasoline coming out from the exhaust huhuhu
fuel pressure....hmmm.....somebody told me bout if ae100 1.3 carb is using 7mm hose, but svt using 8mm, but mine running well for 5 years now, why recently hv this problem...huwaaaaa
cybtech
408
6
O2 sensor... Piston ring bocor.....
donno..... 2 cents
wilm3
500
29
definitely not fuel pipe....7mm still can use....good luck .....
WrX7
266
3,018
try engine diagnostic, this may help to identify the problem area of the engine...
good luck
nafiiio
300
11
5,018
...Send ur car to the best mechanic in ur area after considering all the problem here .. :smokin:
levin818
1,260
321
3,183
Shah Alam
Have you check your ECU?
Almost all '92~'96 SVT's ECU is in bad shape now.
This is a must check item.
I just bought a pair of Airhorn from kedai ptong.......problem is i cannot locate the original place of the horn......n is it just plug n play with the original horn.......do i need an additional relay in order to work.......pls give suggestion n opinion
Thanks:regular_smile:
