Starter can crank but engine won't start
My manual corolla seg stock engine keep giving me this problem. Today is the third time. I am really hopeless now.
First time (2 weeks ago) it happened, just call mechanic, he just open and close the fuel outlet near firewall, then it was ok.
I suspect it could be due to alarm issue, then go and install a new alarm. On that night, the same problem happened again. The installer just use additional wire to connect the fuel wire to a connector to bypass, then it was ok.
This morning, the same issue happens again. After dinner, come back try luck to start, it was ok.
Below is the history
1. the car overheated 1~2 years ago.
2. change radiator
3. earlier engine die off while driving on the road, change distributor, its wiring, spark plugs and plug cables.
4. fuel pump changed
5. recently change engine gasket, timing belt, water pump etc...
What could be the reason? Please help.
Thanks a lot.
2. change radiator
Thanks a lot.
