Show us your lancer/evo pics!
Since it starts with a jump start, you have narrowed it down to an electrical problem. The fuel pump and injectors are new. I would look at those first. I suspect a bigger capacity battery will start it
The thing is, this is the max size that I can use (ns60l) if still using stock battery placement especially since it's small terminals. And previously even with smaller size (ns40) can still start. I am suspect the starter motor for now.
parakey
1,367
226
You can check how much the voltage drops when cranking. I dont think the new camshafts will add much to crank effort.
It is cranking, so why suspect starter motor?
Why need bigger capacity battery? A bit weird since jump can start......:confused:
parakey
1,367
226
His current battery is new. He even tested with another battery. Can only start when jump start with additional power source/battery. How does this not suggest a bigger battery will do better?
Further detail of the symptom, it can start fine when cold but after driving then cannot start again if stop unless jump started! My mechanic says possibly crank sensor, so when hot difficult to start. Based on my reading so far it seems to point the same too.
parakey
1,367
226
My wira had the original starter replaced with a refurbished unit. On hot days, after spirited driving or stuck in jam, starter gets heak soaked & refuses to work. Need to wait for awhile before it does.
Reactions: 6UE5t
sweelt
Nov 6, 2016
2,306
248
check voltage before hot start ?
Probably old car wire resistance higher then, because newer cars are coming with smaller and smaller battery.......lol
lsm1991
1,469
185
ur case in particular, no amount of whacking the starter will help right?
crank sensor, i think u can just cocok and pull the sensor readings to confirm kan?
You have a very strange problem. I don't think it's a starter problem since it cranks, just won't come to life right? Perhaps you have a weak connector somewhere.
Yes, just keep cranking but if jump started with enough juice then it will on. Based on what I read seems to point to crank sensor.
My air cond currently intermittently would stop working, especially when hot.
Honda Service Center informed that the magnetic clutch and coil was faulty and would cost me RM1600 to replace.
Anyone with a recommendation for an air cond shop I can do it locally?
A shop near where I live in Serdang, Selangor informed that they are unable to source original Japan parts and only have replacement Magnetic Clutch & Coils from China. Reading online, there are shops which replace with...
