Evo Malfunction Indicator Light show ?
dkny
211
10
518
Anyone could give me advice, 2 days ago I try my Evo 8 performance.
From Gear 1 to Gear 2, then gear 2 to gear 3, I pedal like 6~7k RPM, suddenly I saw Malfunction Indicator Light show, I immediate change to gear 4, but lower the RPM, then the light goes off.
I wonder is that normal ? So far I haven't see the light on again, but I quite worry.
As I know, if u driving a VTEC Type R, and if your RPM too high, the indicator light will blind to warm you to switch to next gear level.
So, Evo 8 have this function too ?
pangyau
1,153
302
1,683
Malaysia
dkny,
What do you mean on 'Malfunction Indicator Light'?
Or it is the Engine check light sign?
If the Engine check light while you on WOT (Wide open throttle)
Probably due to knocking while you 'pedal to metal'
On standard Evo, Revving Cut around on 7200RPM.
Or you might hit the Red line too long...
dkny
211
10
518
Engine Check Light - On
Anyhow DanzEterna, please share me more information, because I really never heard about Evo 7- 9 have "Shift Lamp" function (I assume same function for Vtec K20 car, which shift lamp on if RPM too high).
Probably due to knocking while you 'pedal to metal' - What mean?
If I not mistaken, 8MR redline is 8-9k RPM ?
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
if not mistaken evo7-9 has the shift lamp correct me if im wrong....need to double confirm with other evo users
'pedal to the metal' means flooring the accelerator.
usually for turbo cars not that high maybe bout 6.5-7k rpm.
mototo
102
31
5,028
NSW
no shift lamp here. 2003 8 gsr running stock boost, stock rom and caltex 98ron fuel.
regularly sees 6k rpm changes.
however, an aftermarket rom might have the CEL set to trigger as a shift light. Check evoscan and evom forums. I *think* I have read this before but for the life of me cannot remember where or when.
victor87
96
19
1,508
It's knock warning but it's only available on flashed rom...
For AFAIK, Evo 8 with flashed rom to have the knock warning, the CEL will stay on regardless any RPM, and it will only blink if knock is detected. For Evo 9, it's stayed off until knock is detected, then the CEL will start blinking if knock detected.
I see 7,800 RPM almost every time i drive my Evo.....
greenmivec
341
126
1,543
Usually for turbo cars not that high maybe bout 6.5-7k rpm.
wrong
greenmivec
341
126
1,543
Evo rev cut at 7,800rpm
Beyond that is re flashed ECU or stand alone ECU setting.
To all pros out there, i need an advice from all of you as i plan to get a new car. My budget is around 60-80k. Ford, Kia, Honda, Toyota, Nissan, Pegeot and Proton; which one is better and worth the price. I'm looking for long term, hope you guys can help out.
Thank you in advance..!!!:biggrin::biggrin:
