Aircond Compressor Draining Too Much Power?
RENESIS VIII
7,063
950
Ipoh
That is silly, right? Pay to get 10bhp to lose it on the air con......lol:rofl:
Off air cond then different story. :biggrin:
Few days ago, I noticed some whining sound from my engine. Brought to my mechanic for a check yesterday and he said the sound came from the compressor pulley. Bearing sound I think. When the compressor is kicking in, the sound disappears. Should I get this fix or leave it?
Off air con no cost mah.......lol
If you can pin point the fault then repair it. If you cannot, then what to repair?:hmmmm:
RENESIS VIII
7,063
950
Ipoh
Oh, then I'll try to go to air cond shop and ask if this can be repaired. My mechanic told me most air cond shop people will just suggest to replace the whole thing based on his past experience. :hmmmm:
Your mechanic cannot replace the pulley bearing?
RENESIS VIII
7,063
950
Ipoh
Nope. He told me to bring it to air cond shop guy to check the problem first. Anyway, I just came back from air cond shop. Indeed the sound is coming from the bearing. Got it replaced and changed the gas inside the air cond system. Everything took like 3 hours plus. So far, it felt like the compressor is not draining as much power as it is before. But today is not a very hot day, so I'll see how it performs again on a hotter day.
This is the bearing.
Compressor one a bit more difficult, have to take out magnetic clutch. Tensioner pulley easier to change......lol:driver:
sweelt
Nov 6, 2016
2,306
248
good bearing tho, nsk japan. If you free can pop out the protection plastic (Brown color). See the bearing condition inside.
RENESIS VIII
7,063
950
Ipoh
This is the damaged one. But the one that is replaced is also the same bearing. NSK Japan.
RENESIS VIII
7,063
950
Ipoh
Got noise means koyak already loh......hhahhahahha
I did ask if it is necessary to replace it since the air cond guy said quite a lot of work. He said if I leave it there, the damaged bearing might 'eat' into the pulley and damage the compressor.
Any bearing got nose means breaking down already. When it jams, there will be no free play, meaning your compressor can be jammed on all the time, sure something will give in the long run.......lol
RENESIS VIII
7,063
950
Ipoh
Oh no. The horror if compressor jammed and not running. No cold air blowing from air cond. :nurse:
The air cond guy told me that I'm quite good and observant to notice this sound from bearing although it is quite soft.
mag9556
2,770
43
1,648
but you will get extra 10bhp :biggrin: :biggrin: :biggrin: :burnout:cabut
Hi all,
I don't know how to explain this but I feel that my 4 wheels like went in abit .. that makes my car look abit weird .. the other day I park my car at somewhere beside there is a Wira .. I check his wheels and mine his of course look better and fierce .. because his wheels fit perfectly .. why is this? Different absorbers & springs combination different result? I also saw some satrias same as mine. I never done before any screw setting becos my front don't come with the screw.
can...
