Pangyau,
I Guess E6 - E9 stock ECU will have self learning ability and adjust the A/F ratio accordingly base on the fuel u pump......this is not applicable for those monster that have too many goodies......I guess u r in the Monster list.....hehe
Now a days very hard to pump V-Power racing ler....so most of them no choice to go for Ron97 fuel instead......My slow ride is always running on RON95 fuel...
My 2 Cent
Just wanna check anyone encounter any problem when using Ron95 on turbo engines ? I am transplanting CM5A 4G93T into my Lancer CK, if Ron 95 can be used do I need to retune ? Or just hope and pray ECU learns to adapt to RON 95 ?
My is eterna and covert to 4G63T also and using ron 95 shell...so far no problem....but less powerful lo...and currently using low boost 0.9 bar...
kampoon,
My ride cannot become monster, everything still in stock mode.
Thinking to pursuit for power but have re-think due to reliability.
Thanks for the review/comment.
Actually I try to find anybody experience it first hand.
Nobody in my place using RON97 on their CT9A (coz the rest kaya except me).
The latest reference/example tested on Airtrack Turbo (stock condition).
The owner facing a knocking/pinging in his engine during city driving (no boosting).
Then he revert back to RON97.
Maybe I need to test myself...
But need to prepare AFR gauge & Innovate Knocking sensor la (very costly) :hmmmm:
Any said problem like pinging and knocking ? As I know diff petrol diff quality sum say shell/esso better while others claim petronas work wonders. I however find that shell/esso no knocking / pinging petronas i encounter knocking and pinging. This is on N/A car which is my daily driver one is aan avanza while another is a kenari. So imagine on a turbo it will be either have no prob or might hurt the engine. I believe the mech sure will reuse my leftover petrol which on the Lancer CK is Ron95 so hopefully everything goes well. :rolleyes:
Hi guys,
Anybody experienced/tried/tested the RON97 on CT9A (E7/E8 or E9).
On stock condition (all standard ECU, Engine & such).
Please share....
Thanks in advance...
Since first day till today, i'm using Shell RON97 on e9. Still consider stock i guess. Not sure what are the difference as i never use 95 or vpower before. So far so good, but jialat on mileage :SHi guys,
Please share....
Since getting my E9, I've been using only RON97.
My E9 is very much stock, except suspension.
No issue so far, everything runs smoothly, although I can't really compare since I dare not try RON95...
Full tank can reach between 380 to 400+km no problem at all.
sub8evo,
What fuel rating requirement is written on your fuel cap ???
Wa bro, full tank reach 380-400?!
Mine if driving around 20km radius for a full tank, 280-300km only
If drive within 30km radius, 300-320km only.
If drive within 50km radius, 320-350km only..
But that one also after i decat my exhaust and upgraded it, and really can feel the diff or power and fuel consumption..HAHAHA
before that, around 30km radius, should be 340-380 xD. but never ever reach 400km before :(
I remember its all in Japanese... will confirm again later.
But, I did search the web and found that for e9 recommended to use ron97 & above.
---------- Post added at 06:19 PM ---------- 6 hour anti-bump limit - Previous post was at 06:16 PM ----------
Bro, it very much depend on individual's driving style anyway. I usually up shift before 4K rpm, and always shift to 6th gear on highway cruising, so this should help in fuel consumption. On average I get 9-9.5km/l.
The other day after the K. Klawang run, the FC dropped to 8.5km/l, but its expected !
before 4k?! I shift before 3k all the time. And even tested full tank and maintain 3k MAX RPM and shift. Cruising in highway with 6 gear and around 3k, which is 110km/h like that. Cause i set my pre-shift light on 3k to control my step on the throttle peddle xD..
That day i nothing to do, and i go pump full tank Esso. And i managed to get 302km! whereby Shell, confirm less than 300. Even currently, 92.8km with shell, the needle already drop down to bet:rolleyes:ween second line and the middle line (Full tank first line, then second, then middle, then fourth, then EMPTY) :/.
Bro, it also depends on the mods in your car - large turbo, stroker kit etc will increase the FC too
wow nice fc solty8. 315km from rm75? mine ah.. last time fill fuel rm70 can go 105km then finish...aredhghhghghghh veryy veryyy tension.now i want downgrade my turbo to stock turbo,,,fedap already heh
Similar threads | |
