...Of course with RON97, you may able to maximize your stroke length to give better power to your engine.
Well...i would say fun things do come with a price.
It is tempted to say with RON97, you may able to maximize your stroke length to give better power to your engine. BUT sadly, it does not.
The invention of various RON is actually to coupe up with the modern engine design, but not all car come with modern engine design that require RON97 RON102 or RON110 because car manufactuer knows these supply of higher RON is can be hard to find and costly
Mixing RON95 97 does not give RON96 likeness, the petrol will stay put as it RON95 RON97 mixture, they are miscible but octance property does not change because we mix them up like that, or else the petrol company will just be producing high RON and mix it to lower RON for the conveniences sake.
Knocking is always misunderstood as pre ignition, but knocking in simple way to explain it is the detonation of fuel, pre ignition is like a more serious problem, sometime intentional too (in racing). Knocking hurt the car, but pre ignition will kill your engine
If you car is running without knocking with 95, if you feed 97, 102 or 110 or 130, your car will not perform any better
in fact 80% of the car I tested in local market , does not knock with RON 95
often time , I got saga, myvi coming in telling me 95 is no good to their car, but i will refill the tank again and prove them wrong... Q: why they hear knocking when they pump RON95
Ofter found issue is the petrol station they use. Their petrol is contaminated. 2 out of 10 petrol station in Malaysia got into severe gasoline contaminated issue, Cause no 1: flood Cause no 2: manmade
often time you will see petrol station close down for weeks or days, because the reservoir need to be empty and to clean it, to seal up the cracks.
by all means... when you pump the fuel, think do you really need it?
