Originally posted by singleguy+Mar 31 2005, 20:02 -->
QUOTE(singleguy @ Mar 31 2005, 20:02 )
--QuoteBegin-Jackie Leong@Mar 30 2005, 23:30
thicker wires = less resistance.. not? :unsure:
[snapback]855094[/snapback]
yes thicker wires less resistant.
but will it like teh flow too much? or since thicker is more expensive.. smaller car actually dun really need that thick?
[snapback]857935[/snapback]
[/b][/quote]
It's not necessarily to be all 4ga cables or all 6 gauge cables. A combination of 4 and 8 or 4 and 6 gauge cables will do.
Thicker won't flow more, but flow easier. What one would like to achieve with grounding is to provide an easier path for the electrical current to flow back to the battery (therefore grounding), or for the electrons to flow from the battery to the components. If the cable is too thin, simply judge by the cross-section, it wll not be effective as the body panels, frames, etc will still be the easier path for the flow.
One simplest way of improving grounding is by adding a think cable to the body from the battery that serve as assistance path to the original grounding cable.
these grounding points are 'a must' if one would like to have an effective grounding:
1. body/chassis near the front bulk head (for brighter lights)
2. engine block (to ground the static current due to heat and friction)
3. alternator (beter overall electrical performance)
4. firewall (dash board instruments, HU, meter, etc)
5. ignition distributor (better spark)
6. autogearbox (if applicable, smoother transmission response)
