What is your Top Speed?
c160 has a higher final drive then c56, just that the ratio is lower.... on c160,4th gear 8000rpm is 165kmh, 5th gear can tarik until 210 already... 6th gear haven try, coz still got speed cut.. muahahaha.....
Gear Ratios :
Years built--------1995.5-1997.3-----------1997.4 - 2000.7
transmission code-------C56----------------------- C160
1st --------------------3.166-----------------------3.166
2nd--------------------1.904 --------------------- 2.050
3rd---------------------1.392----------------------1.481
4th---------------------1.031----------------------1.166
5th --------------------0.815 ----------------------0.916
6th -------------------------------------------------0.725
Reverse----------------3.250----------------------3.250
Final Drive-------------4.312----------------------4.529
on highway, 160kmh is like cruising only.. coz only at 4500rpm...
never regret paying 1.5k extra for 6 speed during conversion...
hm??
Bro scott..
The stats you gave seems like the final drive ratio for c56 lower wor...
hmm... thats from what i know, confirmed with few other website already...
notice that even c160 has a higher final drive, but the ratio is generally lower than c56,
juz for u bro...
Bump: opps.. forgot to mention, 1 mile = 1.6 km, so all the figures times 1.6, can get in kmh already
pluck out from wiki....
C56 http://en.wikipedia.org/wiki/Toyota_C_transmission#C56
A 5-Speed Manual Transmission for FWD cars.
Gear ratios for this transmission.
1st 2nd 3rd 4th 5th Reverse Final
3.166 1.904 1.392 1.031 0.815 3.250 4.312
Applications:
* Toyota Celica
* Toyota Corolla
* Toyota Starlet Glanza V
* Toyota AE101 Levin/Trueno (Later Years only)
* Toyota AE111 Levin/Trueno
* Toyota MR2 Spyder (US/UK/JP) (mid-engine application)
C160 http://en.wikipedia.org/wiki/Toyota_C_transmission#C160
A 6-Speed Manual Transmission for FWD cars including a optional limited slip differential. Transmission with identification code ending with 12C are LSD equipped. Code ending with 12A are non-LSD.
1st 2nd 3rd 4th 5th 6th Reverse Final
3.166 2.050 1.481 1.166 0.916 0.815 3.250 4.529
Applications:
Ah.. I think I understand dy..
the final drive ratio is slightly higher..
But because got 6 speeds, the ratio is closer in between gears..
Nice info guys.. Salute you all.:adore:
So anyways.. a little bit general info.
according to Gran Turismo.. (haha... I like play game ok)
higher final drive ratio always gives higher top speed..
low gear ratio gives better acceleration but lowers the top speed.
Correct right?
Blackie..... your car can go beyond that speed BUT..... due to excess weight..... errr.... enough said.....
Wahhh... monster is here.. haha.
BlackHowling sure boh your car slow..
2J impossible slow la...
my car is slower than everyone here..
only can get 180km/h..
but in 5th gear can go more than that..
6th gear speed drop to 180..
Pivot baby speed meter showed 247km/h ...it was 3 years ago...now engine almost kaput... :(
but this one...hmmm... :D :D
old picture...hahahaha...
247 was for real...VSS was working fine...
300 was with faulty VSS...hahaha...
bone stock with "minor" modifications... :driver:
speedo went crazy...it was fluking like crazy...
changed VSS sensor..all went back to normal...
mine old KE30 can reach 180kmj...that was the limit of the meter..hehhehe...
Soli newbie here,wat is VSS?tq
Bump: Soli newbie here,wat is VSS?tq
Probably means Vehicle Speed Sensor bro...
Hey.. last night I testing my BT top speed..
Feels like lagging hell when 160kmph climbing to 170kmph...
Auto gearbox really sux..
i'm now dealing with a erratic speedometer which likes to wobble and it only happens about 50% of the time. could it be due to faulty VSS sensor? did you have this problem as well when your speedo was faulty?
Write your reply...
