cruise democar...the engine is too hot, even the blue head cover paint peeling....
KL already got one hehehehe.... but ae101 SEG body....
here are the spec:
One Owner
Cruise Demo Car
Front Wheel Drive Drag Spec Turbo (AE111)
Mission and Sus Changed 3000 kms ago
Escort Forged Piston
Jun Super Conrod
OS Twin Plate Clutch
Toda 272 9mm Lift Cam In/Ex
HKS F Con V Pro
TD06-20G Turbo
Boost 1.5 / 490ps
Blitz 850cc Inj
Cusco LSD Type RS
6 Point Roll Cage
HIDs
Spec Sheet (Left in the car with Cruise Headings):
(Parts Changed)
Clutch Release Pedal
Diff Side Bearing
Diff Side seal
Bonnet Duct
Front Pipe Outlet
Intercooler Piping
0.8mm Racing Metal Head Gasket
One Off Oil Catch Tank
Injector Insulator
Cam Seal
Blitz Surge Tank Gasket
Mani Gasket
Crank Pulley
Blitz Wastegate Gasket
Toyota 6 Speed Mission (New 3000kms ago)
Valve Spring
Slide Cam Sprocket
Full Engine Tuning (Honing, Block Skimmed, Shim Adjusted etc etc)
Cam Cover gasket and washers
Cusco p/s pump (pulley)
e/g exhaust valves all new
fly wheel changed
new valve lifter
decat pipe
strengthened crank
vavle seat cut
ports enlarged
head skimmed
head fully tuned
valve clearance adjusted
ADDITIONAL NOTES
Juran Front Tower Bar
Custom Manifold
Blitz Wastegate
Screamer Pipe
Solid Suction Pipe
HKS Induction Filter
Radiator Slam Panel
Sard Adjustable Fuel Pressure Regulator
Aftermarket Turbo Elbow
Aftermaket Downpipe
Aftermarket Front Pipe
Aftermarket Horn
Aero Front Bumper with Cruise custom intake Ducting
Aero Side Steps
Rear Spoiler
Cruise Stickers
Aftermarket Brake Pads
Slotted Rear Rotors
Trust Intercooler
Blitz Ignition Leads
Recaro Recliners with matching Rear Seats (Factory)
Momo Race Steering Wheel
Razo Pedals
Razo Shift Knob
Greddy 60mm White Electronic Boost Gauge
Greddy 60mm White EGT Gauge
Greddy 60mm White Electronic Water Temp Gauge
Greddy 60mm White Electronic Oil Temp Gauge
Greddy 60mm White Electronic EGT Gauge
Blitz Power Meter
Autometer Monster Tacho with Shift Change Light
HKS EVC Boost Controller (Late Model)
Blitz Turbo Timer
6 Point Lagged Cage
15″ Alloys
Titanium Exhaust System
Endless Function Coilovers (VGC)
APP Stainless Mesh Brake Lines
Rear Under Suspension Brace
Foam Filled Frame (Done by some tuners for Rigidity, cuisse being one)
Greddy Oil Cooler and Filter Relocation Kit
Kenwood CD / MD Double DIN
HKT Fan Controller
HKS Twin Power
my god...the list....cruise democar...the engine is too hot, even the blue head cover paint peeling....
here are the spec:
One Owner
Cruise Demo Car
Jun Super Conrod
HKS F Con V Pro
TD06-20G Turbo
Boost 1.5 / 490ps
Blitz 850cc Inj
Cusco LSD Type RS
6 Point Roll Cage
HIDs
(Parts Changed)
Diff Side Bearing
Diff Side seal
Bonnet Duct
Front Pipe Outlet
Intercooler Piping
Injector Insulator
Cam Seal
Mani Gasket
Crank Pulley
Valve Spring
Slide Cam Sprocket
fly wheel changed
new valve lifter
decat pipe
strengthened crank
vavle seat cut
ports enlarged
head skimmed
head fully tuned
ADDITIONAL NOTES
Custom Manifold
Blitz Wastegate
Screamer Pipe
Solid Suction Pipe
Radiator Slam Panel
Aftermaket Downpipe
Aftermarket Horn
Aero Side Steps
Rear Spoiler
Cruise Stickers
Slotted Rear Rotors
Trust Intercooler
Razo Pedals
Razo Shift Knob
Blitz Power Meter
Blitz Turbo Timer
6 Point Lagged Cage
15″ Alloys
HKT Fan Controller
HKS Twin Power
