What could be the problem?
sorrow
Calling all for help,
just now was fixing a new bulb to my center console...
later found that my hazard light when on, also on the demister icon...
proceeded to try and salvage the situation but end up now
my alarm, clock, head unit and amp no power.....
can anyone advice me on what could be the problem???
check the fuse for room clock under your dashboard driver side
provided u are driving a wira, satria or putra
Just share my experience. HU, cigg socket, clock not function. after few hours looking for the source of these trouble later found out that the acc fuse actually was burned. under the steering, fuse compartment, check the acc fuse (15w), if burned change with new one and hopefully ur problem solved.
But how come the demister light will come on with the hazard light? Did you connect the demister to the hazard switch socket?
Hiz all,
I'm driving AE101....
I just checked my car .... the clock actually is on but it is very very dim...
when i turn on my headlights.... the clock would actually be brighter when it should be dimmer.. (IE, normal case, headlights off=clock bright, headlights on=clock dim)
and my demister and hazard light sockets are two different sockets altogether, so the probability of plugging into the wrong sockets is absolutely zero....
just only, something spectular came up.... instead of blinking demister icon with the hazard lights....
Now is only left hand signal is on when hazard light is activated....
:confused_smile:
try to unplug the new bulb n see...maybe the center console tat bulb burned because of short-circuit?
and now u replace wit a new one and causing other component to short?
:confused_smile:
tried and tested, the problem doesn't seem to lie with the bulb.....
.sighs :confused_smile:
update on the completed repair works..
1. Found two fuses in the engine bay blown.
2. Some copper wiring of meter cluster observed to be broken.... electrician used wire to short the broken area. I see not broken but according to him, its broken.
New Posts
