water level reduced...
wilm3
dear sifus...just curious tat why my water spare tank water level will reduce .... and i need to refill evry 2 days....the problem is i can't found any leaking at radiator, spare tank and hoses.....why??? pls advice...tq
me no sifu... but
check the radiator cap!!!
when the rubber loosen, sometimes water sips through it ler!!!
or what you can do is - put in coolant (beeter if green) then do some investigiation ler!!
good luck!!
cheers...
mine water in both tank also keep decreased untill certain level then wont reduce again.. wat prob ar?.... i using 1.1 radiator cap oledi ... ..
suspect is water pump lo.. damn...
ya.. happen to me... water pump leak... after changing.... then water level maintain.
mine also decrease when long hour driving! green water menitik from no idea where come from! cannot find where located ?
Its a leak la. Change the cap (damn cheap) not TRD la. If hose more than 5 years change lor. If radiator suspect leak, must disasemble do compression test.
open yr radiator cap... fill it to the fullest... start yr engine.. let it idle.. see if got bubbles comes out.. if after awhile.. got bubbles...
gong xi fa cai..
i'm using TRD 1.3 radiator cap...last time used Ispac 0.9....any problem wif tat?? if got bubbles mean....water pump kong....???
i think got bubble means ur head kong.. right?
and also check a 2" rubber hose below the intake manifold connected to water pump.. there also easily leak..
all above are correct...
or you can try to pour in the radiator coolant with leak detection...the green color one...
if there's a leak...the green color coolant will show the leakage...heeee...good luck on the findings...
finally found out the radiator's head is leaking.... thanks for all's advice....
Write your reply...
