Voltage manipulation
drexchan
Bukit Jalil
Hello electronic heads...
need some help here..
I need an electronic circuit to:
1] From DEVICE A
input voltage: 4.75V to 5.25V
max input current: 0.1 mA
output voltage range: 0.50V to 4.50V.
factor P determines the output voltage, V1.
V1 (0.50V to 4.50V)
2] first stage
to multiply V1 with a certain factor, m. The output, V2 should be adjustably 50% - 150% of V1.
V2 = mV1, m = 0.5 to 1.5 ...................... EQ. 1​
3] second stage
to constantly add (or substract) a certain adjustable voltage, c to (or from) V2, irregardence of its value. For example, constantly adding 0.50V to V2.
V3 = V2 + c, -0.5 < c < 0.5 ...................... EQ. 2
combining EQ.1 and EQ.2,
V3 = mV1 + c ...................... EQ. 3
if m = 1, c = 0, V3 = V1 (not adjusted)
4] To DEVICE B
what other details do you need. Let me know.
What is DEVICE A and DEVICE B.. you guess lar.. haha!!
Thanks in advance!!
so you want a circuit that will multiply input voltage V1 by factor M and further add to a variable voltage C?
what kind of input current are we talking about?
differ said:
so you want a circuit that will ?
Should be "multiply input voltage V1 by a variable factor M and further add to a variable voltage C"
source current to DEVICE A = max 0.1 mA
output (V1)... unspecified.. should be the same right?
Thanks first..
Another forummer suggested this:
I think it will be much easier to use PIC controller or any microC for this application. Need to use ADC and DAC. Get the signal from DEVICE A and feed into ADC. Do some math processing and use DAC for output to DEVICE B.
shoots...i have already returned my basic electronic back to my lecturer already..
hmmm, at the tip of my brain... can't we just use an differential Op-Amp for the multiplier and then a standard voltage summer circuit
sorry , just found this topic. still blur..
maybe DC to DC converter kot..
5V convert to 12V.
12V convert to 28---30V.
correct if wrong.
bro drex, is it the current output totally does not matter? if u just need signal (ie, uA's of current, then easier control by PIC.... ) can make a hard coded electronic circuit design also.. but accuracy is of question.
I have abandoned this project for a long long time already. I can't even understand what I wrote! LOL!
