turbo questions
L2TurboFool
guys..i haf a few questions that i would like a proper answer for it..
1-set boost at xxbar e.g.= 1.0 bar...
y is that?? y does sum1 need to set the boost at that bar?
is a higher boost setting better?? i would like pros and cons sifus..thanx..!
2-wats a wastegate?hahah i knew this..and i forgot..cant remember..
3-and can anyone gimme the specs of mitsu. engines? like 4G63/t and so on..
thanx...not very sure of the types and specs.. :lol:
thanx again dudes..!
1.) bar is just a unit for measuring the boost pressure , some use psi as well. Higher boost of course will lead to higher power as we would like to see back the basic equation , do when u add more boost which means forcing in more air into the engine and of course u need to compensate with the amount of fuel goin into the engine.
more fuel+more air=more horsepower.
2.)wastegate : is a device that bleed off extra exhaust gasses so u wont overboost with your turbo at your preset boost level ( spring stiffness in your actuator/ external wastegate)
3.) i don tknow much on mitsu engines... only rotaries and protons and nissan =)
cheers
oh okay...thanx dude...appreciate it..
ne1 can give me the specs of mitsu engines??
thanxx..!!
i can help u with the 3rd one...
mitsu. claimed:-
4g63 vr4 cyclone - 200 & 220
vr4 eci-multi -240
4G63 evolution 1 - 250
2 - 260
3 - 270
4,5,6,7,8 - 280++
4G93t GSR - 180
4G93t 1800RS - 210
