es2611 said:bro acoustic..really nice article there..now i kno a bit..just got my set of Titan for my kelisa
can u advice me on something..im kinda new in this world..but eager to learn..
currently im using 14inch rims..can i upgrade it to 15inch??
if yes..can u pls advice me..do i have to a new setting for the abs?
currently im happy wit the setup although i really dont kno wat the guys at Titan did to it..
i want to see the car abit low..but not sacrificing the comfort..like bro acbc bro said maybe nice for me 70% comfort and 30% performance..help me pls.
and bro..wat series for the tires should i used if i can upgrade to 15inch??
and can u explain about the pillow ball stuff too
thanks a lot in advance sifu
changing rim size in normal consideration does not affect the suspension, hence you can change whatever you want. but the 1st thing is to maintain overall external diameter so that speedo meter remains accurate.
although change from 185 to 195 affects handling, but we should not mix it with the suspension.
the bounce also affects when change from 60 series to 50 series.
speaking of this different types of tyre materials also affects bounce ... and on and on ... forever .... so as long as you can separate the analysis then OK.
other things you slowly read around, you will know ....
Pillow ball .... depends lah ..... you ask Richard - need long time to explain.
