What is
TiTAN custom build performance shock absorber?
TiTAN's are proudly 100% Malaysian designed and built custom build performance shock absorber. Designed as the ultimate custom build shock absorber set for Malaysian roads and drivers! TiTAN's been around for 5 years.
TiTAN is an
inverted monotube design, ala WRC/Rally cars style for maximum strength AND durablity for Malaysian roads.
What is a monotube?
a monotube is a single tube where all the damper oil, hi-charge gas and piston is inserted into. Imagine a tube with a sealed end on one end. and a removable cap on the other. (diagram included later)
What is an inverted monotube?
it's the upside down version of the monotube, but in this configuration, the barrel (where all the oil and piston is located) is the exposed moving component moving up and down. Any damage to this surface will not be sufficient to cause ANY leakage of the damper oil as the shock rod is protected inside of the body.
WRC cars ONLY use this setup as it offers HUGE reliablity compared to conventional monotubes.
One of the best reasons ppl use
inverted monotube for the MacPherson struts setup is because of the better(alot!) strength laterally. Normal struts have thicker rods (for fronts) for strength. Rears are small cause there's no lateral load there.
inverted monotubes are stronger anyday because it's way way bigger in diameter.
Is it servicable?
YES ! TiTAN sets can be serviced at anytime, as it's designed to do so. Because we use superior designed seals and over-specced seals and bushes, we're so confident, we give
2 years(!) warranty for normal usage against defects in workmanship and materials, excluding finishes. (ie:paint)
When we service, we change the oil, (synthetic shock absorber oil) seals, bushes and maybe valves all to new ones.
What makes TiTAN's so special?
We designed our product such, it has a modular materials design to save costs. But we over-specced the materials kau-kau. Why? Malaysian roads are notoriously horrid, with the occasional pot-hole and bumps on the road to work. And for the price you're paying for a set of shocks, you'd expect the shocks set to last ! (at least for 18-24 months right?)
And after all that, you'd want to service the shocks/dampers and have it perform again like almost new. We're one of the few suspension local companies that can service shocks
properly (TiTAN's only) and it only cost you RM300 per service of all 4. This includes the installation, parts, new and fresh damper oil and the neccesary work.
What do you mean custom-build?
Custom built for you! We humans are very complex human beings. We all want different things to satisfy our specifics needs and wants. What Mr. A wants differ from what Mr. B wants. So to accommodate almost any individual, we try to as closely as possible, to tune your TiTAN to suit you!
This means, spring rates, damping rates can be changed to suit the individual!
We have a variety of springs to choose from, and valving tunablity is very high because of the large damper piston we use.
What cars do you build for? Do you build my car?
We can build sets for just about any car that uses the oil-damper setup.
This means cars that are using air-type suspension like the new Mercedes S320 may
not be suitable. The Citroens with pneumatic hydraulic system is not suitable as well.
This would mean about 90% of the cars, trucks or even ATVs can be TiTAN-ed!
if you're interested, and not sure if your car can be TiTANed, call us!
CALL -> Stanley 012-211-3039
TiTAN's are great for cars that have difficulty getting parts for their suspension, as we can build and service(!) such as the Mercedes 124 (model just before the big and small headlamps model)
What's the pricing?
Prices are located on this link:
TiTAN's pricelist
We charge according to amount of work and materials needed, not by the brand of the car installed. Hence Mercedes' sets are cheaper than a Proton Satria GTi.
(Mercedes' are separate springs and damper)
Why the price??
Our manufacturing costs are high, simply because of the economies of scale. We're not a mass production facility. We're running a very labour intensive (more precision, better quality control) production line (if you call it that) AND our materials are delibrately over-specced, and only good quality materials are used in TiTAN's construction. Our seals and bushes are equally superior, and all that adds up to it's final retail price.
What's the warranty like?
Limited Warranty
For TiTaN Custom Build Shock Absorbers
I. What this Warranty Covers
Defects in materials and workmanship in the following “products” manufactured, sold or certified by MPd Auto Centre Sdn Bhd, with which this limited warranty is included in/on the package: (1) spring(s) and damper(s) set (2) seals and oil seals (3) bushes and bearings.
II. What the Period of Coverage is
Subject to the following exceptions, 2(two) years from the date of Purchase by the first end user:
Motorsports usage exception. Use in motorsports is not covered as the conditions of during use is unknown and subject to very high stresses, abuses and high use. We do however; guarantee that our product(s) will be free from defect in materials and workmanship until used in competition/race/rally conditions.
• Paint finishing exception. Warranty does not cover mars, scratches, chips and such after use. We do however; strive hard to ensure that our product(s) are protected from the elements.
