steering problem
skyline2m
Kota Kinabalu
i just want to ask about my car steering. i've change my steering tie rod end but the problem still occur. the problem of my steering is when the road is incline in even bit, my car will not go straight. i need to turn a bit of my car steering to opposite direction of the inclination to the road condition so that my car will go staight. my car has a good allignment too. can u guys help me as soon as possible
may be the pinion and rack of m car is the main problem...
Check your both lower arm rubber.The one that connected with knucle.Try that one first...cheers
how long do u never pump air for your tyres?
if all the above tried.....then u go petrol station and pump even the tyres with air.
I believe my fren here pump the tyres with even preasure. The car will start to turn right if the road is incline to the right. So everytime he need to counter it back.. on normal flat road its normal..
The same problem with my sis Kancil. As if the front wheel is loose from the steering a lil...
hehehe.... hope he can settle it fast. we want to go play2...
could it be the front tyres condition getting old or something?
cheers
as ealt said, could be the lower arm rubber... hv u changed those as well?
cheers
