From http://paultan.org/archives/2005/07/08/the-petronas-e01/
See this article from Paultan.org
http://paultan.org/wp-content/E01.jpg
You’re looking at the product of the first Malaysian commercial engine project, the Petronas E01.
This project started back in March 1997 with a collaboration between Petronas engineers and development partners. The engine applies
knowledge gained from taking part in Formula 1. The result is a powerful engine,
up to Honda K20A performance standards.
The engine was designed in two phases. The first phase involved training Petronas Engineers in areas of Computer Aided Design and Computer Aided Engineering. Actual design and engineering of the engine was done in the second phase of the project, supervised by development partners.
The engine start-up ceremony was held on 20th February 1998, and four months later on 23rd June 1998, the engine was finally installed in 2 cars, a Proton Waja and a Proton Satria GTi.
http://paultan.org/wp-content/E01_2.jpg
The PETRONAS E01 can be installed about
15 degrees tilting forward or backward within the engine compartment of the vehicle. This allows the engine to be
fitted into any model of cars. Versatile! The picture above shows the Petronas E01 installed in a Proton Waja.
Aesthetics-wise, the engine really looks great. The DOHC cover is in black and green, and look at those polished stainless steel extractors! Yum! The engine is not only pretty to look at. Let’s have a look at it’s technical specifications.
Technical Specifications
Valve mechanism: Continuous Control VVT (Variable Valve Timing)
Camshaft: Double OverHead Camshaft (DOHC)
Displacement: 2 litres
Induction: Natural Aspirated
Cylinders: 4, In-line
Valves per cylinder: 4
Block: Aluminum
Weight: 108.9kg
Max Horsepower: 204.3 PS @ 7300rpm
Max Torque: 203Nm @ 5300rpm
Power Output per litre: 100 PS/litre
Volumetric Efficiency: 107.8%
Emission Standards: EURO 2
Original design targets for the engine was 200ps max power, 200Nm torque and 120kg weight. So basically PETRONAS engineers managed to exceed their original design targets.
As a benchmark, the Honda K20A makes 220PS but at a higher 8000rpm. Maximum torque is equivalent to the E01 at 200Nm, but maximum torque is only achievable at 7000rpm while the PETRONAS E01 gets max torque at a relatively low 5300rpm.
http://paultan.org/wp-content/satriagtie01.jpg
The Petronas Satria GTi, spotted at Mutiara Damansara area. Picture courtesy of http://macxcess.com/vblog/blogger.html.
http://paultan.org/wp-content/satriagtie013.jpg
Sadly, news has been going around that this
engine has been bought by Hyundai because
Proton did not want it. They chose to focus on their own Campro instead. How many of you would have been interested in a Gen2 R3 with this monster of an engine under the hood? I know I wouldn’t mind.
