don't get debetz, the amp watt rating fake to the max
u just look at the fuse volt they use then u know
rogers use high volt fuse compare wif debetz
debetz 2ch only use 20-30v ampere fuse
while rogers use 40v ampere fuse. rogers amp powering component set are quite good. the power output is good enuff to power midrange componet set.
bridge it, and u can power a single 300watt 12" subwoofer.
debetz....add or dun add no difference. better dun buy.
