Replace tyre onot?
EcstacyElmo
K Hell Shitty
my rear tyre was punctured before, so i had it patched, it was ok for quite awhile, i think bout 6 months or more back.
recently the air started leaking out again, so now i'm not sure whether to repalce the tyre, or repatch it, if its possible. my tyre is only 1 year old, same age as the car. but of cos the wear on the punchtured-before tyre is more than the other tyres, sometimes i didn't notice the air was less then other tyres n kept driving, so the thread wear is different.
can anyone advice me wat to do? repalce or repatch. cos if replace, replace 1 tyre only?
i afraid get hurt by another nail again, can patch till yr tyre weared off just replace. my perdana 1 tyre got 5 nails le, i go patch back cost RM25 only...
i face da same prob. well, i just stick with it, til all 4 tires wear off, and change all together.
u stick it??? stick with what??? ya use till wear off just change, now tyres not tht cheap lo
so i can send it to tyre shop to repatch the same hole then?
hopefully not another puncture la, the last time i did patched it the guy said the tyre can last til need to replace, but i didn't know air wil start leaking again.after about 7 months.
1 week hav to pump air twice. haih.
if financial is allow, i will suggest to replace the tyres at least in pair (front or rear pair). But if your area got construction. still with the patch, just don't travel in highspeed.
Hmm,maybe you should mend your tyre else where because the last time I mended mine it only cost me about 15 bucks.But yeah,mending it is pretty economical.
oh!!! same hole??? if the hole is big difficult lo, twice a week!!! i think mayb got hurt by nail again. u must check again
yeah i'll go check tmr, see if can re-mend the same hole....hopefully it possible ahaha
if another nail means bad luck la
thanks guys
this is the correct way!
3 things when owning a car...
1. Never scrooge on tires.
2. Never skimp on brakes.
3. Never ever rojak suspensions.
Hell yes to that. Tires are the only things keeping you on the road without them, your car isn't worth anytihng. If finances allow, you should get them all changed. If finances don't, they should be the next thing on your to buy list. Hopefully there is still sufficient thread left on them..
Write your reply...
